Prop Testing
Old 11-07-2004 | 02:02 PM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
Default Prop Testing
well my Bullet hit 77 this mornng with sto0ck 26 Bravo 1 props turning around 5300
water was flat temp upper 50s
with some tweeking and on salt water hoping for 80 wit a good current LOL
klaw is offline
Old 11-07-2004 | 03:07 PM
OldSchool's Avatar
Default Re: Prop Testing
Those are good numbers Gary!!! Flat water slows me down about 5 mph. Get it back out there with a good 2 foot chop and you've got 80 easily!!
OldSchool is offline
Old 11-08-2004 | 08:14 AM
OldSchool's Avatar
Just curious Gary, Did you have your new engines dynoed?
Old 11-08-2004 | 08:57 AM
klaw's Avatar
yes the numbers were
578 ft-lbs @4500 and 559 hp @ 5600 the horse power was still climbing at the rate of 2 hp per 100 rpm at this point but I think I was going to run out of carb.
klaw is offline
Old 11-08-2004 | 10:23 AM
HOUSTONPROP's Avatar
you need a little chop to lift things up and maybe hit the mark lab the props and bump them up 1' in pitch.
HOUSTONPROP is offline
Old 11-08-2004 | 11:34 AM
throttleup's Avatar
Klaw,
I would try a set of 24 Bravo 1's. Your motors need to spin up based on your dyno numbers.
Since Ket West is right down the road from you are you going to be there during the Worlds next week?
We will be set up in the dry pits. Stop by and we can talk about your set up and goals and make some suggestions about what may work for you.
Matt
throttleup is offline
Old 11-08-2004 | 12:45 PM
24'S WOULD SLOW IT DOWN ,It would get the rpm up but you need the higher pitch props for the forward travel which in the end result more speed .
we can get 300 rpm out of working the 26 pitch props. Darin
Old 11-08-2004 | 03:08 PM
throttleup's Avatar
Gary,
It's all about the torque band of the motor.
Nice talking to you, look forward to meeting you in Key West. You won't be able to miss us in the dry pits. It's going to be a blast.
Matt
Old 11-08-2004 | 08:00 PM
I am with ya,flat water will slow it down,but the 26,p. labbed and some other tricks of the trade will make it come on quick.
Old 11-09-2004 | 07:27 AM
klaw's Avatar
well this has always been a interesting topic which I have read about in car tests sometimes a car will actually run faster in 4th gear rather then 5th gear if you have the hp to get to a higher rpm.
I will be in the position to test this in my boat because I will have a set of 26 and a set of 24 props and will run them both.
In the end I will probably will have both sets of props because I like the fact the 26 give a better 55 mph cruise rpm but since I do boat alot on a river the hole shot of the 24 will be nice and if it truly can give nme more top end the better.
klaw is offline
