There has got to be a better way to remove old vinyl >
Old 11-14-2004 | 09:38 AM
GregP's Avatar
Default There has got to be a better way to remove old vinyl
I've tried the heat and strip method and it works fine for some of the stuff but the bottom piece of the boot stripe just refuses to come off in anything bigger than 1/4" chunks. I'm sure it was cheap/thin vinyl, but there has to be something that will just melt the stuff and wash it off. I'm not going to remove 70 feet of stripe one 1/4" chunk at a time.
Help!
-Greg
GregP is offline
Old 11-14-2004 | 09:53 AM
Steve_H
Default Re: There has got to be a better way to remove old vinyl
rasor blade.
round the corners with a file so it wont dig in.
Old 11-14-2004 | 10:08 AM
Steve_H
theres also a rubber wheel you can buy that will take it off.
http://www.offshoreonly.com/forums/s...ighlight=vinyl
Old 11-14-2004 | 10:11 AM
Scott's Avatar
Charter Member #30
Try This
I'm not sure if this is the exact product or not but have heard this type of product works great.
I would try your local Auto paint supply store.
I have Steps & Bubbles!
Scott is offline
Old 11-14-2004 | 11:15 AM
eraser wheel , i can send you a pk if you can't find locally. e
open87 is offline
Old 11-14-2004 | 11:24 AM
MitchStellin's Avatar
Sand Blast? Router BUY A NEW BOAT
MitchStellin is offline
Old 11-14-2004 | 11:48 AM
mcollinstn's Avatar
solvent won't work.
Vinyl and/or polyester are two components in gelcoat. A solvent that melts the decal will also melt the gel.
If your stickers have not been painted or cleared over then heat is your friend.
And a properly used razor blade is your tool. If you can't use it without gouging gel, then a honed edge like mentioned will help (but use a stone or a finished concrete floor to hone the edge, not a file).
The guys who have used the eraser wheel have reported good things. I've always used heat and blade.
mcollinstn is offline
Old 11-14-2004 | 01:11 PM
GregP's Avatar
I made some progress by turning the heat gun up to "paint removal" temp and scraping the vinyl off with a deburred putty knife. Got as far as I could reach from the lift/dock, will have to wait for a higher tide to get my work float in place to do more (extra low water today due to the north wind, the work float is aground on the shore line). Maybe I'll also get warmer than a 40 deg day, but I think I'm running out of chances for that.
Didn't see the small eraser wheel locally, found an ad for a professional system for only $400 ... not quite ready to resort to that yet unless I can find a place that rents them.
-Greg
GregP is offline
Old 11-14-2004 | 01:47 PM
cuda's Avatar
I used a razor scraper to remove it off my old Formula. It comes off pretty good once you get it started, keep getting it! Then I took the old adhesive off with mineral spirits.
cuda is offline
Old 11-14-2004 | 02:29 PM
Try Easy Off Oven Cleaner, it takes off paint and stickers. Try it in a small area first.
wananewboat is offline
