Gen 5 cyl head gasket mis match >
Old 11-15-2004 | 06:57 PM
PatriYacht's Avatar
Default Gen 5 cyl head gasket mis match
After I pulled the heads on my gen 5's, I noticed a water passage on the far left that is covered by the gasket. There is a matching passage in the head. The gasket is a Felpro 17048. Should I open the gasket up?
Attached Thumbnails Gen 5 cyl head gasket mis match-cylhead.jpg   Gen 5 cyl head gasket mis match-cylgasket.jpg
PatriYacht is offline
Old 11-16-2004 | 01:58 AM
Linster's Avatar
Off the Radar
Default Re: Gen 5 cyl head gasket mis match
Do not open that up. It is blocked on purpose to make the water flow to the end of the block. If you open it up, water will short circit the head by coming in the water pump inlet & and right out the intake manifold outlet.
Linster is offline
Old 11-16-2004 | 07:25 AM
PatriYacht's Avatar
Thanks, I can see what you're talking about.
Old 11-16-2004 | 07:50 PM
Payton's Avatar
Charter Member #927
Ian, why all the soot on your pistons? It's been a while since I've been inside an engine, but is that normal?
Payton is offline
Old 11-16-2004 | 09:35 PM
Smitty's Avatar
That looks like a normal amount of carbon to me. Better a little black then brown or white.
Smitty is offline
Old 11-17-2004 | 06:43 AM
Payton's Avatar
Charter Member #927
That makes sence.
Payton is offline
GNJ
3
05-23-2007 12:15 PM
ur2slo
08-17-2006 10:01 PM
HPJunkie
4
03-02-2004 11:40 AM
traviss
6
12-06-2002 06:35 PM
