Drive Alignment Tool for XRs >
Old 11-16-2004 | 09:09 AM
Default Drive Alignment Tool for XRs
What is the P/N for the alignment tool for XRs?
Is it different than the standard Bravo tool?
Where is the best, translated cheapest place to get one?
Has anyone had them made for sale?
Shawn
shawn is offline
Old 11-16-2004 | 11:22 AM
Wally's Avatar
Were doomed!
Default Re: Drive Alignment Tool for XRs
hmmmm......i would think its the same as the bravo tool. Only because you can install the x series drives inplace of a standard bravo.......just being a bearing change from what i understand.......maybe just have to machine the bravo tool for the new bearing size now that i think about it???
-Wally
Wally is offline
Old 11-16-2004 | 11:36 AM
BoatStuff
I looked up 91-805475A 1 for the standard transom and 91-840965A 1 for the integrated transom models.
Old 11-16-2004 | 12:15 PM
HiPerf2000's Avatar
The X style gimble bearing has a larger ID for the larger input shaft on the X drives. I forget how much bigger, but i thought it was like .050 or somehting???
anyway the standard bravo alignment tool will fit through the gimble bearing, but there will be a little play in it (.050 or so) due to the larger ID of the bearing.
I didn't hear of a new one that came out. maybe Merc doesn't think that .025 slop (.050 divided by 2) would be cruicial in aligning a motor ?
HiPerf2000 is offline
Old 11-16-2004 | 12:50 PM
Breathe Later's Avatar
The bearing ID for XZ/XR bravos is the same as std. B1 drives. The width of the XR/XZ bearing is slightly different, but the same alignment tool works for both.
Breathe Later is offline
Old 11-16-2004 | 01:53 PM
Wally's Avatar
Were doomed!
ah so its wider?? more support??? may be a nice upgrade for a standard bravo one if the bearing needs to be replaced
-Wally
Wally is offline
Old 11-16-2004 | 09:31 PM
If you are purchasing an alignment tool, get the one for the ITS. It can be used for all Bravo's and it is easier to use.
I think all of the newer Bravo transoms now use the new shorter bearing. Someone correct me if I am wrong, but I believe you can tell if it's the shorter bearing because it has a red paint dot on it. I will look closer at one tomorrow and get back to the thread if I am wrong.
Falcon is offline
Old 11-16-2004 | 10:01 PM
HiPerf2000's Avatar
it does have a red dot.
and it is a shorter bearing....not larger ID like i thought earlier. they say it is shorter to give clearence for the larger u-joints on the X series.
Old 11-17-2004 | 05:52 AM
Mbam's Avatar
Offshoreonly Advertiser
What Falcon said. Serial # 0M and up all come with the new bearing.
Mbam is offline
Old 11-17-2004 | 07:21 AM
HiPerf2000's Avatar
found the service bulletin for the Gimble Bearing..........
File Type: pdf
