gen vi block
New blocks? Sallee Chevrolet seems to be a favorite.
Used ones, I have a 454 (2000 7.4 MPI) that needs #1 cyl. sleeved. Still has crank, rod's, pistons although #1 piston is scrap. It's a 7.4 so you may not care about the cast rotating assbly anyway. It had about 250 fresh water hours on it when a valve dropped. #1 piston didn't fair so well, neither did the cylinder wall.
Originally Posted by Python82
If you were going to build a 540 would you start with a gm 502 our would you buy a merlin block?? Money is a factor as well???
what's the specs on your motor??? I ready to get rid of my 454!
did you have problems with the merlin heads?? I have a set of them as well and i was debating on using the on the 540 that I want to build. I would like to find a proven setup that I can build this winter. Around the 625-650hp with no blower.
The problem was I bought 345 intake runners which with the compression I was running turned out to be to much. The new owner had the 454 shaved down to raise it which after one season his engine builder believes the stock heads are to small and they want to buy the Merlins and shave them down. The motor is going on a dyno in the next few weeks and they believe it will be 700 to 750hp. The combo I had with the heads and mild cam was around 550hp.
