Some advise please on new boat purchase..
I am considering the purchase of a new go fast. Here is my wish list: 30-32 hull length (not including swim plat), No porposing, keel sway or chine walking, 496 Merc power,
gentleman's boat - with windshield, some amenities (encl head) but no a/c, superior build quality and fit/finish, terrific factory support. I don't need the fastest boat on the planet and it must be a v bottom, 8ft beam. Formula was leading the pack but I test drove 2 Fastech hulls (31/35) and they both porpoised. Sonic 31 has no windshield (has a fairing) and no local deal support (NY Metro). Suggestions please.
Contact Sunsation. They are running a special right now on their new 32 Dominator with 6.2's for 99,999. Upgrade to 496HO's for about 16K....116K for a new 32, seems very reasonable to me. I'm in the market for this same size boat so I'll be interested in seeing the results. Good luck in your search.
Dave
Dave
You can make boats porpoise, and you can correct porpoise with correct drive trim to trim tab balance. Usually you can get away with a conflicting tab to drive setting when it's kind of choppy, but when you hit a calm spot it will start to bounce.
My point is not to tell you how to run a boat, but to say it's a coincidence that both of those Formulas happened to porpoise.... and to suggest that if it's even a remote possibilty that you didn't have enough seat time to get things balanced out during the test ride. I mean because every boat is different, not because you don't know what you're doing.
I don't want you to pass up a boat that would otherwise work fine, if the porpoising is really just a trimming out tweak.
Just my .02 because I had some porpoising with my 26 until I learned what combinations made it worse or better. I used to say my boat porpoised. Now I say that I was the one porpoising. The boat stopped doing it after my learning curve with that particular vessel improved.
I would happily trade my 26 for either Formula (31 or 35)
If you're not looking for new, try a 31' Cig Bullet. You wont' be disappointed in the ride.
John
www.sunriseuph.com
John
www.sunriseuph.com
I am considering the purchase of a new go fast. Here is my wish list: 30-32 hull length, gentleman's boat - with windshield, some amenities (encl head).
You could always look at sunseeker or Cobalt.
I had a 31 Scarab Viper with 365's that did not exhibit any porpoise, chine walk or keel sway. No matter what I did with trim and tabs, I couldn't get that boat to exhibit any bad handling characteristics. I've had plenty of seat time driving these boats..The dealer claimed the porpoise was due to an imbalance inherent to any ventilated/stepped bottom
design.
design.
I have also looked at the Formulas but have not had the opportunity to drive any of the FasTechs. I assumed you are looking at new boats and not used? I have a short list of boats I am interested in based on the $$ and both Formula and Sunsation are on my list.
design.
design.
Allroad, had a 98 Formula 312 w/ 502's and it liked to "bounce" at mild cruising speeds. It liked to run fast. Have a buddy that had a 99 312 w/ 454's and he experienced the same thing. I had a 2000 353 w/ 500's and it ran great. Have talked w/ other 312 owners and they also thought that the 312 was not one of Formula's best efforts. Probably why they don't make this model anymore. Good luck, Wrink
