Billet XR or Teaque Platinum XR >
Old 11-19-2004 | 03:34 PM
mcraymond3's Avatar
Commercial Member
Commercial Members
Default Billet XR or Teaque Platinum XR
Has anybody got any experience with either the Billet Marine XR or the Teaque Platinum XR?
mcraymond3 is offline
Old 11-19-2004 | 04:36 PM
Semper Fi's Avatar
Default Re: Billet XR or Teaque Platinum XR
I've heard alot of good things about Max Machine Works in Lake Havasu City, AZ. I've heard alot of good things about Teague's drives also. I would probably stay away from Imco, being that they don't offer a warranty.
Semper Fi is offline
Old 11-19-2004 | 07:37 PM
articfriends's Avatar
Go with the max machine worx,iv'e had good luck with them. As far as a warranty,i don't think ANY of the bravo derivatives have a warranty but IMCO refuses to even help so stay away from them!!!
articfriends is offline
Old 11-20-2004 | 04:51 PM
mcraymond3's Avatar
Commercial Member
Commercial Members
How much are th eMax Machine worx drives?
Old 11-21-2004 | 05:40 PM
right around 10,000 outright
Old 11-21-2004 | 08:16 PM
2112's Avatar
Smitty,
Is that the entire unit?
2112 is offline
Old 11-22-2004 | 01:59 PM
2112,that is entire unit from input shat to prop shaft all new and upgraded,give aaron a call and he can give you exact price,it varies depending on options,Smitty
Or give too old a call as it appears he's now a dealer!!
Old 11-22-2004 | 09:45 PM
Max is a great drive. I have a pair on my Fontinan, no troubles, and great customer service.
Go Big is offline
Old 11-23-2004 | 07:26 PM
Linster's Avatar
Off the Radar
Max definitely has the advantage on the tower. There top cap is also good. They also offer a caged gear bearing that is .060 larger than the Merc XR non - caged bearing. They grind .030 out of the gear and put a -.030 bearing race on it. They still use an XR shaft. I do like IMCO's Pinion shaft so you save on the universal.
I had a IMCO blow up with 5 hours. This was after 75 hours, stock Bravo, with the same engine. They did not offer any warranty. It took out the tower on the Bravo. Max fixed that. I do not like the IMCO tower. Its probably the worst I've seen. It just pressed in.
I'm not sure of Teague yet. I have not had any apart or no anybody who has one.
Linster is offline
Old 11-23-2004 | 11:09 PM
Linster,are you talking about the upper gears(grind .030 out for bigger bearing). They USED to do that but the tradeoff on durability wasn't worth it so they leave the bearing bore in the xr upper gears stock dia,i know this because i broke one of the first xr gears they were modifying that way,even though they offer no warranty they admitted it wasn't a great idea and took care of me,can't beat their customer service,Smitty
