Fuel pumps?
Old 11-22-2004 | 07:18 AM
dyno's Avatar
Charter Member #655
Default Fuel pumps?
I bought some cam driven water pumps for my Gen 5 454's to clean up the front of my motors so now I need to get some electric fuel pumps to replace the ones on my stock seapump. Who's would you use? Im less than 550hp and running a 800 holley.
Don
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 11-22-2004 | 07:25 AM
Smitty's Avatar
Default Re: Fuel pumps?
I've had good luck with the holley black fuel pump. I did have to remove the pressure spring and stretch it a little to get the fuel pressure that I wanted, but that only took a few minutes. The black pump also has the port for a hose to the carb so it is coast guard approved.
Smitty is offline
Old 11-22-2004 | 12:41 PM
Registered User
I have used Holley Blue Pumps but had problems with both. I went to an Aeromotive pump with a bypass regulator.
excalibur81 is offline
Old 11-22-2004 | 07:07 PM
Vinny P's Avatar
I hate the winter!!
I just picked up a complete system from Aeromotive. I got their 11108 pump, 13207 regulator, pre-pump filter, after pump filter. I am also running an Edelbrock mechanical pump as a redundant system with a check valve to prevent back flow.
Vinny P is offline
turbosonoma
1
10-09-2007 12:25 AM
tanner
1
08-30-2007 03:31 PM
Shah Mat
3
07-03-2004 12:42 AM
35/25
4
09-15-2003 11:42 AM
XCAV8
19
06-23-2003 06:59 AM
