AMSOil Pre-Charger Systems... >
Old 11-24-2004 | 10:06 AM
Sydwayz's Avatar
Forum Regulator
Default AMSOil Pre-Charger Systems...
Any experience? I like the way these things operate. Does anyone have them on their boat? 496HO by chance? Do you see your Oil Pressure go up when Ignition turned on?
Basically, this is not a system that pressurizes your whole oil system, but rather squirts 160cc of oil into your oil system when you turn your ignition key on. It goes on pretty easy from what I read, and they have two systems.
AMK-01, the “bolt on” configuration, is designed for use in combination with the BMK13, 15 through 18 Series Dual Remote Mount Filtration Systems.
This system basically replaces your screw on oil filter with this system that pipes your oil over to their mount with Two Oil Filters, and the Pre-Charger, all in one piece.
AMK-02 is a “stand-alone” configuration designed for universal application. The AMK-02 can be used with any engine application and mounts at any angle.
This system is place inline of your oil system, between the filter and the block.
Full info on both Pre-Charger and the Dual Filter System:
http://www.amsoil.com/products/amk.htm
http://www.amsoil.com/products/bmk18.htm
I am considering both of them, but not sure which to purchase. I may even purchase one for the truck, as it only gets used/started on the weekends.
Sydwayz is offline
Old 11-24-2004 | 10:31 AM
Sydwayz's Avatar
Forum Regulator
Default Re: AMSOil Pre-Charger Systems...
Marine Dual Filter system:
Dual Remote Filter system with Bolt-On Pre-Charger:
Stand-Alone Remote Pre-Charger:
Sydwayz is offline
Old 11-24-2004 | 10:36 AM
Sydwayz's Avatar
Forum Regulator
496HO pics from AMSOil Website:
Attached Thumbnails AMSOil Pre-Charger Systems...-1.jpg   AMSOil Pre-Charger Systems...-2.jpg   AMSOil Pre-Charger Systems...-3.jpg
Sydwayz is offline
racesdad
OPA/The Jersey Boyz
5
06-08-2008 09:25 PM
Sydwayz
11-24-2004 08:43 PM
bluewater7
5
08-31-2004 10:25 PM
GLH
04-10-2004 05:24 AM
