pitch vs diameter
If I get a 25 pitch hydro thats 14.5 diameter or a 24 pitch hydro thats 15.5 diameter would the rpm be the same? I have to think it would, and the 25 would be a bit faster. Any other opinions on this one?
The RPM should not be the same. With all things equal you should expect about a 150-200 rpm difference in rpm with each 1/4" diameter change.
There are many factors that determine diameter. Each boat and set up may require a different diameter. The number of blades on the prop will also determine the diameter of the prop. The only way to find the optimum diameter is to test by reducing diameter until you have gone too far, then go back to the optimum diameter.
Matt
Matt
Dueclaws,
It's very common to reduce the diameter of the speedmaster props. We take great care when doing it to make sure that the desired result is achieved. There are some calculations that help to determine if reducing the diameter is the right course of action. Other factors such as the use of the boat and current and desired handling properties also play into diameter adjustments.
Matt
Matt
Originally Posted by Dueclaws
Matt
I'll probably need some help with my 40' Jag cat. But the thought of trimming the #6 props too far is a bit scary. Maybe your experience can help here.
John
John
Steamin Rice
2
09-28-2004 05:15 PM
