Switching tabs from Insta Trim to 280 K planes >
Old 11-28-2004 | 11:22 PM
outlawinil's Avatar
Default Switching tabs from Insta Trim to 280 K planes
Hey guys wanting to upgrade my Insta Trim tabs on my 33 Outlaw to the 280 K-planes. Is this the best choice for this boat with 500 HP's in now? Do I use the Mercury pumps or will the Insta Trim pumps work? I have the round Insta Trim LED tab indicator, will I be able to use this gauge or will I need new indicators?
outlawinil is offline
Old 11-29-2004 | 04:49 AM
Biggus's Avatar
Default Re: Switching tabs from Insta Trim to 280 K planes
Pick up a set of Trick Marine tabs from Too Old.
I recently replaced my K-Planes with Fred's tabs. They are quite a bit less than K-Planes and much better looking, polished stainless cylinders. I had mine powder coated to match my drives.
Attached Thumbnails Switching tabs from Insta Trim to 280 K planes-dcp02661-medium-2-.jpg
Biggus is offline
Old 11-29-2004 | 04:51 AM
Biggus's Avatar
Here's another pic. These things are extremely heavy duty and are offered in every color imaginable.
Attached Thumbnails Switching tabs from Insta Trim to 280 K planes-dcp02664-large-.jpg
Biggus is offline
Old 11-29-2004 | 07:34 AM
Dave M's Avatar
Veteran: Navy
I prefer mechanical indicators. If you have the dash space. Those that pop up out of the dash are cool.
Dave M is offline
Old 11-29-2004 | 07:38 AM
Audiofn's Avatar
Charter Member #232
You will have to replace the pumps definatly. The guage you will also have to replace with a Mechanical unit. The Mechanicals can be just for your tabs or for the tabs and drives. You will like them MUCH better then the Guage anyhow. So factor that into the costs as well as cables. You also need to add that into the time of how long it will take to make the swap. I have also seen Biggus's Trick Marine tabs and will agree that they look fantastic. May be a great option to save you some money. I am fairly sure that it uses all the same mounting and indicator hardware as the Merc Units.
Jon
Put your best foot forward!
Audiofn is offline
Old 11-29-2004 | 07:48 AM
Hi-Tech Marine's Avatar
Go with the TRICK Tabs. Better value for the dollar.
Hi-Tech Marine is offline
Old 11-29-2004 | 08:02 AM
Ed
Those TooOld tabs look very nice. The only thing I see that is questionable on the installation is that they have been installed a bit too close to the side of the boat, which will cause water deflection off the sides of the tabs, as water comes around the sides of the rear corner of the transom. This creates a rooster-tail, so to speak. Every boat is a little different, maybe you won't have this problem. After installing a few hundred sets of these, you tend to catch the details, sorry. Ed
Ed is offline
Old 12-01-2004 | 07:29 AM
The only comparison between the Trick tab and the K-Plane is in the mounting holes. These usits are far superior and available to match the boat. Fred has done his homework and came up with a great design.
THLWL
Black Thunder
22
08-19-2009 03:23 PM
Pete280
Powerquest
3
11-21-2006 08:20 AM
outlawinil
0
11-28-2004 11:16 PM
bajaboy2004
1
08-04-2004 05:49 PM
Julio
6
07-10-2003 11:04 AM
