any idea's ? >
any idea's ?
any idea's ?
Old 11-30-2004 | 11:51 PM
Cool any idea's ?
Have a '90 Baja sport 30 ft. I'm running built 454's with approx. 475 hp. each. Problem is when I get to around 1100 rpm the boat starts to pull to the left. As the rpm increases, I must turn the wheel more to the right to keep going straight. At 50mph I have the wheel turned almost half.
whats puzzling is out of the water I have checked for slop. As soon as I move outdrive the steering wheel turns. I do not have external steering as yet . When you look out back, the wake appears to be in line with each other.
team Tickfaw is offline
Old 12-01-2004 | 06:43 PM
monsta
Default Re: any idea's ?
Check your drives to see if they are toed in or out. Also I would check the props , maybe one is damaged and not giving you a vibration. And do the engines tach out the same, possibly one engine is attempting to carry the other. Good luck!
Old 12-02-2004 | 07:19 AM
KAAMA's Avatar
Steering systems = SAFETY
What you are experiencing happens a lot with stock steering especially when steering parts/components are or become loose and should obviously be checked out and adjusted, etc. I'm not sure how much money you want to pour into this project, but an inexpensive route would be that you could probably get away with some sort of external steering stabilizer rams of some kind that work in conjunction with the stock steering system which would probably help to some degree. I'm sure you know this already, but for really nice, SAFE steering you need an external full racing type of steering system all the way up to the helm.
A good full external racing type of steering system is the best choice especially above and beyond 50-60mph+ speeds for handling and SAFETY purposes.
KAAMA is offline
Old 12-02-2004 | 08:49 AM
Smile Re: any idea's ?
In regards to the tachs, at idle they are the same, but at 3000 or so the starb tach will read 800-900 more. The sync gauge will read even though. The gauges are faria. I'm taking the props off after weekend and having them serviced although they look fine.
Does anyone have a used external steering they may want to part with?
On the toe in, the outdrives appear to be straight, maybe slightly toed in,hard to tell.
Thanks for the help,
kenny
Old 12-02-2004 | 09:25 AM
Wally's Avatar
Were doomed!
Is this a bravo drive setup or TRS??? if its TRS you may have a tranny going bad......if bravo try looking at the props to see if they are solid or rubber hubbed....maybe the prop hub is bad.....
-Wally
Wally is offline
Old 12-02-2004 | 09:35 AM
They are bravo drives and rubber hubbed props 25 pitch.
Old 12-02-2004 | 09:54 AM
Payton's Avatar
Charter Member #927
475 hp is a lot for a rubber hub. I would some solid hubs.
The 454 Mags 365hp came with solid hubs, I think.
Payton is offline
Old 12-02-2004 | 05:48 PM
With that said about the hubs I will double check this weekend. You may be correct on the solid hub. Was kind of wishing they were rubber and had one slipping a bit to cause some of my problems. Thanks for the reply.
Old 12-02-2004 | 10:03 PM
Quiet Storm's Avatar
team Tickfaw
Where are you located. I have a pair of 25's solid hubs that I never intend to use again. If yours are rubber the solid hub may be your answer.
I also think you could use external steering.
Quiet Storm is offline
Old 12-03-2004 | 08:38 AM
Arrow Re: any idea's ?
I live in Tylertown Ms. I boat on the Tickfaw river in La. Will be going down there this weekend and plan on pulling props then. I am wanting to put the hyd. steering on and hoping someone out there my have a line on a used one.
also how do you adjust the toe in / toe out on the outdrives? By the tie bar?
[email protected]
