Sportmasters steal speed?
Old 12-02-2004 | 03:11 PM
Default Sportmasters steal speed?
Hi!
I wonder if sportmaster lower units steal speed when run less than 85 mph gps compared to a lower unit as XR. According to Merc Hi performance they only reccommend a sportmaster lower unit for outboards if running in excess of 85 mph. If not it steal speed. The main reason for sportmaster lowerunits is high x dimension (low water pickups) / eliminate blow out. How is it for inboard lower units?
Any ideas?
Cheeeers, Toffen G
Toffen is offline
Old 12-02-2004 | 03:22 PM
Ed
Smile Re: Sportmasters steal speed?
The hydrodynamics are the same principal in both sterndrives & outboards. Ed
Ed is offline
Old 12-02-2004 | 03:38 PM
Default Re: Sportmasters steal speed?
Hi!
I have seen several boats on this webb with sportmasters running around 82 mph. In principal they should swop lowerunit to gain speed.
Cheeers, Toffen
Toffen is offline
Old 12-02-2004 | 03:39 PM
Sydwayz's Avatar
Forum Regulator
I bet once they are dialed in, they will get you a tad bit of MPH.
However, I watched a friend of mine pick up a brand new to him 30 Eliminator that had SM lowers installed, and were never tested before he bought the boat. First time out the boat would not get on plane at ALL.
Sydwayz is offline
Old 12-03-2004 | 08:47 AM
Biggus's Avatar
Last spring I re-rigged a friends 22' Scarab with a new 496 HO/ ITS and a standard XR drive. Mercury did not recommend the Sportmaster and said it was designed for boats over 85.
I felt the regular XR was much too deep mounted on the ITS (stock x-dimention) the boat only ran 67 mph.
At the end of the season, I bolted up a new Sportmaster and instantly picked up 5 mph! No problems with planing at all.
Kurt
Biggus is offline
Old 12-03-2004 | 10:31 AM
L9X25's Avatar
I was told that the Sportsmasters were slightly less hydrodynamic than than a normal lower unit because the design was intended to reduce/eliminate the high speed blowout that is more common with the normal design.
L9X25 is offline
racer-x6
Drives and Lower Units
11
08-08-2007 08:24 AM
Panther
06-27-2007 09:30 AM
docmanrich37
Prop Talk
2
02-11-2006 10:40 AM
SMOKE THIS
07-26-2004 10:10 PM
Donzi Corleone
07-28-2003 06:12 PM
