Intercoms/WHAT IS THE BEST DEAL? >
Old 12-03-2004 | 08:05 PM
plumbers crack's Avatar
Talking Intercoms/WHAT IS THE BEST DEAL?
wHAT IS THE MOST POPULAR ?PRICE?HOW GOOD IS THE STEREO WHEN PLAYED THROUGH THE HEADPHONES AND SO ON? tHINKING ABOUT INSTALLING ON NEW BOAT.
plumbers crack is offline
Old 12-05-2004 | 02:56 PM
Re: Intercoms/WHAT IS THE BEST DEAL?
helloooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooo?
Old 12-05-2004 | 04:04 PM
Smile Re: Intercoms/WHAT IS THE BEST DEAL?
I installed the Revolution Marine Intercom system in my boat this summer and it has worked very well.I had a couple of problems with the main box,but the owner was very helpful and fixed the problem with no questions asked.I tried both the boom mike and the throat mike and decided to go the throat style.They were a little uncomfortable at first but you get alot better reception and alot less wind noise past the 80 mph mark.The stereo comes in clear but sometimes it is hard to hear.I think the system was around $1800.00 for a 4 man system.The system was very easy to install and had more then enuff wiring for the boat.I would recommend this system to anybody looking for a intercom.
ThunderChris is offline
Old 12-05-2004 | 09:40 PM
Default Re: Intercoms/WHAT IS THE BEST DEAL?
Tigerperformance systems are the best on the market. I have installed these systems before. The common problem is not hearing your stereo through them very well. The fix for that is to install a line drive on the rca output that runs from the main intercom box to the stereo. The line drive will boost the level that comes from the stereo to the headphones bringing the audio level up to a useable level. Without the line driver you have to turn the squealch up real loud to here the stereo which works for that, but as soon as someone talks over the system, their voice is way too loud. The line driver is just simply a boost for the audio signal. I believe that Tigerperformance includes a line driver now in their packages just for that very reason.
Sight and Sound is offline
Old 12-06-2004 | 05:04 AM
dyno's Avatar
Charter Member #655
I have an aviation set-up that works fine for less than $400....
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 12-06-2004 | 01:57 PM
TomFTM's Avatar
Dyno , Do you have any info on the avation system you have? Thanks, Tom
TomFTM is offline
Old 12-06-2004 | 02:55 PM
dyno's Avatar
Charter Member #655
I bought them from Gulf coast avionics, I have a portable setup they have panel mounted also. They are on the web along with several other pilot shops just surf around, Sportys pilot shop is another I can think of. I love mine they take all the wind noise away so I can hear the engines better as well as my passengers. If you have any wind sheild they work fine if you take tons of wind you can get throat mics and that goes away but I'll bet you get a funky tanline... If you are ever in West Michigan I'd let you try mine before you buy.....
dyno is offline
Old 12-06-2004 | 05:58 PM
Thumbs up Re: Intercoms/WHAT IS THE BEST DEAL?
Thanks for the replies!I thought the passengers would get a kick out of being able to talk and listen to the tunes without screaming and turning the mute button on and off.Sometimes you want to hear the engines and then the music.But $2,000 bucks,I could get bigger amps and f the passengers
Old 12-06-2004 | 06:08 PM
BRUCE SEROFF's Avatar
http://www.boatcommunications.com/bo...boat_main.html
http://www.sampsonracing.com/sampson...new/home_f.htm
http://www.racingelectronics.com/marine.html
BRUCE SEROFF is offline
Old 12-19-2004 | 05:16 PM
bob
Charter Member #40
Has anyone ever tried the Flight Tech Intercom? So cheap, maybe too good to be true?
bob is offline
