tach is fluttering >
tach is fluttering
tach is fluttering
Old 12-10-2004 | 05:20 PM
Default tach is fluttering
I have 1990 454's with thunderbolt ignition. I put new v.d.o gauges in and one jump's around anything under 2000 r.p.m above it is fine. I switched tach's from port to starboard and get same results with both tachs. does the tach pickup from the coil or the ignition module? Thank's for any imput.
Formula29 is offline
Old 12-10-2004 | 07:58 PM
38KV's Avatar
Default Re: tach is fluttering
From the coil ( -) Gray wire.
38KV is offline
Old 12-11-2004 | 06:27 PM
carney's Avatar
I had the same problem with a pair of 525Sc's , I found the rotors were loose on the dist shaft. Merc says to locktite the rotors on. let set for 24 hrs. this fixed mine. good luck.
carney is offline
Old 12-12-2004 | 08:22 AM
I have a single SBC in a Volvo Penta boat and had tach jumpping all around and traced it back to a poor connection. I dunno if it was at the tach, the engine connection or the coil. I cleaned all of them and it fixed it.
happy hours is offline
Old 12-12-2004 | 08:26 AM
The Menace's Avatar
Ditto to what I had.
The Menace is offline
SCARAB98
Wanted
1
05-31-2008 04:37 PM
SCARAB98
Scarab
1
05-30-2008 10:17 PM
SCARAB98
2
08-20-2007 03:34 PM
thespy
1
05-21-2002 11:00 AM
