Best Aluminum heads >
Best Aluminum heads
View Poll Results: Who has best Aluminum heads
Brodix
9
13.24%
Dart
14
20.59%
World Products/ Merlin
3
4.41%
AFR
24
35.29%
Edelbrock
7
10.29%
Other
11
16.18%
Voters: 68. You may not vote on this poll
Best Aluminum heads
Old 12-13-2004 | 01:25 PM
Smitty's Avatar
Default Best Aluminum heads
I am in the market for some Aluminum heads for my 502's I am building up. Who do you think has the best heads. Right now I am leaning towards Brodix heads. I am staying with stock compression, a mild cam and Whipples at 8 PSI of intercooled boost. Looking to hit 750 HP per motor.
Smitty is offline
Old 12-13-2004 | 02:51 PM
cstraub69@comcast
Default Re: Best Aluminum heads
There is no best head, just good combinations. You could spend $15K on heads and if the the combo is not a matched system all you will end up with is a lot of money spent on something that doesn't run.
Chris
Old 12-13-2004 | 04:10 PM
44MTI's Avatar
About any will make 750hp with that setup.Would you be interested in a used set of Brodix 2.I am going to buy some new CNC ones. These made 730 hp on n/a 598's with hyd cams and pump gas.
44MTI is offline
Old 12-13-2004 | 04:19 PM
bigd1's Avatar
from a noob - besides weight, what's the benefit of aluminum -vs- iron?
bigd1 is offline
Old 12-13-2004 | 05:25 PM
Heat dissipation. smoother air through the transfer ports. Will overheat faster and expand faster than cast and leave you with cool looking boat anchors.
jimslade is offline
Old 12-13-2004 | 08:16 PM
10x's Avatar
10x
10x
If you're buying new ones, go with the Profilers. They're really not any more $$$ than anyother of the CNC'd ones. With a little bit of massaging by the right person, they WILL out flow all the others. If you're lookin to save some $$$, just go with good used ones.
Remember.....You get what you pay for, and sometimes that great deal will cost you more in the longrun. Just my $.02
Fountain powerboats rule "The Preacher"
Chicago Powerboat Club Director
[email protected]
www.chicagopowerboat.com
10x is offline
Old 12-13-2004 | 08:52 PM
Probably I would go with AFR heads. They will produce bigger numbers with the right combination to go with them.
Steet is offline
Old 12-13-2004 | 08:53 PM
737jetmech's Avatar
I have no complaints with Edelbrock marine heads. They make good power in my set-up.
737jetmech is offline
Old 12-13-2004 | 08:57 PM
JCPERF's Avatar
The new Dart 18 degree chevy head hands down the best head in that category.
JCPERF is offline
Old 12-14-2004 | 07:26 AM
KAAMA's Avatar
One of the pro & cons of aluminum vs cast iron is that with the aluminum heads you can get away with running a higher comp ratio, and still not get into detonation, whereas the cast iron heads you cannot. Here's the flip side---I am not a metals guy, but once you are into detonation with aluminum heads they tend to melt much faster vs cast iron heads. I am sure there are exceptions to the rule, but most likely, if you detonate a cast iron head it won't hurt the casting like it will with aluminum heads---cuz once they start to go, they go quickly. I hope I said all this correctly. Perhaps someone else can chime in here as well.
KAAMA is offline
