Freeze - will this work? >
Old 12-14-2004 | 08:05 AM
aTX427's Avatar
Default Freeze - will this work?
We are expecting high 20's tonight and I was thinking about running my engine lights to keep the bilge warm while keeping the batteries on the chargers. I hate to go throught the process of draining the engines or running antifreeze - especially since it was in the high 70's last weekend and this only happens a few times during the winter.
aTX427 is offline
Old 12-14-2004 | 08:24 AM
mcollinstn's Avatar
Default Re: Freeze - will this work?
yeah, it'll work.
Those bulbs don't have a long life span so don't count on em for too awful long. 2 months, tops, if they are new.
mcollinstn is offline
Old 12-14-2004 | 08:31 AM
BajaRunner's Avatar
I also live in austin. will just draining the blocks and exhaust be good?
BajaRunner is offline
Old 12-14-2004 | 09:29 AM
t500hps's Avatar
21 and 42 footers
I have hung 2 drop cord lights into the bilge with 100 watt bulbs to provide warmth. 2 incase one burns out. You can remove the drain plug to check for light to see if the bulbs are still burning. Note: lights will not last all winter running 24-7. This also doesn't provide warmth for the drive if any water is left in there.
Russ C.
t500hps is offline
Old 12-14-2004 | 10:11 AM
SeaRay Jim's Avatar
Last year I used a timer set to come on about 4-5 PM and go off at 6-7 AM. Mines in fully enclosed so even it the temp is cold during the day, the heat from the sun keeps it warm enough inside. Of course this is in North Texas too.
SeaRay Jim is offline
Old 12-14-2004 | 11:49 AM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
go to local home supply center and get one of the oil filled radiators they are cheap insurance and no exposed heating element
klaw is offline
Old 12-14-2004 | 12:32 PM
Chris288's Avatar
I wouldn't think the engine compartment lights would be enough,, what are they like 25 watts ?? I would run a drop light with atleast a 100 watt bulb, and yes drain the block.
Chris288 is offline
Old 12-14-2004 | 12:44 PM
fund razor's Avatar
Do two drop lights.
One for insurance.
Drain the block and the exhaust manifolds (if applicable).
You can skip the antifreeze if you do the rest.
fund razor is offline
Old 12-14-2004 | 01:16 PM
aTX427's Avatar
aTX427 is offline
Old 12-14-2004 | 01:20 PM
fund razor's Avatar
I live too far north.
This was an issue for me two months ago, and I won't be out of the woods until April.
