Kiekhaefer Zero Effort Throttles >
Old 12-20-2004 | 10:00 AM
Thunder1's Avatar
Default Kiekhaefer Zero Effort Throttles
Well, I just got stupid, that would be more, dropped my throttles and broke one!! Is it possible that may know someone or have a throttle lever for sale? Color is not a problem since I am having them re-powder coated but wanted to check the forum and see if possible to replace without buying new. Hope everone has a great "Holiday Season" and thanks in advance for your help!!
Karl
Thunder1 is offline
Old 12-20-2004 | 10:09 AM
Smitty's Avatar
Default Re: Kiekhaefer Zero Effort Throttles
Try calling a place called Kendor marine. They are just south of Milwaukee Wisconsin and I have seen several new/used ones on the shelf. Sorry I don't have the number here at work.
Smitty is offline
Old 12-20-2004 | 10:13 AM
Thunder1's Avatar
Thanks Bigwavz, I'll give them try and see what they have...
Karl
Thunder1 is offline
Old 12-20-2004 | 10:14 AM
Reed Jensen's Avatar
You should be able to buy a replacement part from Mercury......
Reed Jensen is offline
Old 12-20-2004 | 01:26 PM
i have a set of graffig livorsi mint cond, separate throttles & controls, with trim switch, just switched to chrome
customryder is offline
Old 12-20-2004 | 04:45 PM
I have a pair. Black 30 degree angle. $150 delivered. You could keep yours as a spare.
[email protected]
BenPerfected is offline
Old 12-20-2004 | 04:50 PM
blue thunder's Avatar
Remove the broken stick and have a good welder patch it up. I broke one last year and the welded stick is stronger than the others.
BT
blue thunder is offline
Old 12-20-2004 | 05:15 PM
Thunder1's Avatar
Thanks guys!!! Reed, Ben Perfedted and Custom, I am trying to stay away from new or replacement but if things don't work out I will get back with you to see what can be done... Blue Thunder, thanks for the welding idea but it took a multiple break and doubt that the look of what it would take to put it back would be satisfactory. I am checking a couple of folks for used and will just have to see. Thanks again guys for all of the input and with my luck I'll bet I'll be calling you soon.
Thanks very much, Karl
Thunder1 is offline
Old 12-20-2004 | 08:54 PM
ratman's Avatar
a GOOD welder can weld almost anything back together. wilson mainfolds would cut an intake apart modify it weld it back together. then shot blast it to look unmolested and the nascar tech boys did catch it for years... so do be afraid of having something alum or steel repaired. just have to find a highly skilled welder not some bone head that knows how to hold the gun and turn the machine on and off. just my .02 ratman
ratman is offline
Old 12-21-2004 | 08:15 AM
I just sold my used KK throttles and shifters to Sean here on OSO. He was only using 1/2 of each assembly and should have one of each lever left. If you're interested, try posting on the swap section "wanted".
Due
Dueclaws is offline
