Land & Sea Model 600 Hydro Electric Transon Jack
A friend of mine is trying to rebuild the hydraulic pump on his L&S Jack Plate. L&S has no info to give him. Anyone know what the pump is and where he could find an assembly diagram for it? Thanks for the help.
Shawn
Shawn
You can use a regular Merc trim pump on those if you have any or can buy one. Or is this the one that has the entire system all in the bracket? If it is all in the bracket we swapped out the ram on one and put the trim pump in the boat. I can try and find out what piston we used if you are interested.
Jon
Jon
Put your best foot forward!
Thanks Jon, this is one of the self contained units with everything on the jack plate. Any recommendations you might have would be great. Thanks.
Shawn
Shawn
They used 2 different types of OMC outboard trim pumps.Some parts are available through OMC depending on which pump. I went to a local hydraulic shop and matched most of the o-rings when I rebuilt mine.
SUPER AIR
08-24-2006 06:47 AM
Chris288
06-23-2004 01:54 PM
