power for electric fuel pumps ?
Is the 12v wire going to the coil able to handle the extra load on it now? If anything, I would think a relay that got it's signal from the coil would be better. Thus allowing you to pull a dedicated lead for the pumps from elsewhere.
Yes. Here is what I did. Use a pressure switch that makes when you have oil pressure. Feed it with 12 volts and use the output to fire a relay that will switch a good power source to the fuel pump. Lose oil pressure or someone turns the key on you have no fuel pump. If need be you can jump the pressure switch to fill the float bowl but this has never been a problem for me. There are pressure switches that will only make when cranking or when there is enough pressure to close them. In any case use a relay to source good power to the pump.
I went to electric fuel pumps last summer. When I connected them up I did the same and took power from the purple wire at the coil. I burned out both pumps within a 1/2 hr. It was an expensive lesson...
The best way is with a relay and direct power from the battery.
Kurt, you should really be running the pumps from contuous-duty relays or solenoids, along with an oil pressure switch wired with a starter bypass.
When I bought my Cigarette the pumps were wired to the positive coil post on the Thunderbolt ignition and I had intermittent ignition operation a few times.
Yup, never hook to the coil for power, the coil or the fuel pump will die a horrible death-and quickly too. A relay and a pressure switch is the best set up.
The ignition ( purple) wire should be isolated to only fire a solid state relay( most dependable in the marine environment). The ground for the relay should be tapped into a oil pressure regulated hop switch. Relay primary leads should be of 10 ga. and signal leads of 14ga. all of tinned copper. Figure in your resettable breaker, and you'll have a very efficient and trouble free circuit.
