What to use on the boat.
Old 12-23-2004 | 08:04 AM
racer-x6's Avatar
Default What to use on the boat.
LIke everyone, I have put the boat away for the winter. It's kept inside a shop with the covers on. The other night I had a Nightmare That a rat got in the boat and, you can figure the rest. My question is, what could I put in the boat to deter them from looking to make a home in it?
racer-x6 is offline
Old 12-23-2004 | 08:05 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
Default Re: What to use on the boat.
A snake
US1 Fountain is offline
Old 12-23-2004 | 08:08 AM
racer-x6's Avatar
Then the wife won't get in it ??????? Hmmmmm Then the wife won't get in it. Hmmmmmmmmm That will work
racer-x6 is offline
Old 12-23-2004 | 08:13 AM
MnFastBoat's Avatar
Charter Member#157
I have always used dryer sheets every where
just make sure the area is dry where you place them
also helps take away the smell in hte spring time
This Cat is trying to keep up with the Big Dogs
MnFastBoat is offline
Old 12-23-2004 | 08:14 AM
Indy's Avatar
Member #154
I used moth-balls/moth crystals in various places in the cabin, cockpit, and engine compartment. I made sure to get some down in the stringer area in the engine compartment so they wouldn't have a party underneath. It worked well.
Indy is offline
TEAMBAJA's Avatar
What smell?
TEAMBAJA is offline
Old 12-23-2004 | 08:17 AM
Ginger or Mary Ann?
Originally Posted by TEAMBAJA
What smell?
From the Rat pizz of course!
Old 12-23-2004 | 10:34 AM
t500hps's Avatar
21 and 42 footers
I have put those little boxes of rat/mice poison in key locations inside the cabin and cockpit. Figured if they got in there, they would do too much damage before they croaked.
t500hps is offline
Old 12-23-2004 | 10:41 AM
glassdave's Avatar
Neno the mind boggler
i use the dryer sheets to. seems to work. also use them in the summer and i dont get any boat spiders.
08 OPA High Points Champion
glassdave is offline
Old 12-23-2004 | 11:03 AM
jtmiller02
Never use poison, traps only..if you poison them they will crawl somewhere and die, leaving no trail to find them but a smell that will absolutely drive you insane. With a trap all you do is pick the sucker off and reset for another.
