mp3 in boat
Got an MP3 player for Christmas.
My offshore has a sterio with cassette where I can plug in the MP3 player using the cassette adparter.
My center console has no radio...so here's the question...instead of buying a radio to interface the MP3 player into....can I use an car amp with good speakers and have the MP3 player as the input to the amp and use the MP3 player volume control to adjust listening?
Thanks and Happy New Year!
Jeff - Mich.
Jeff - Mich.
As long as your MP3 player has analog outs it will work. We did this in high school with walkmans.
Sounds like a pain. I would install a kill switch to the power-on lead to the amp.
This way in an emergency you won't be fumbling with the little buttons on the MP3.
Should work fine. What type of MP3 did you get?
May check here to see if there is a moe elegant solution.
http://www.the12volt.com/installbay/
hey jon, i've got an ipod with itrip which plays through the radio with no wires...it's an fm transmitter. it works pretty good but sometimes quality is poor and you get static. any thoughts on how to add this on to an existing system? do they make output adapters that will plug into an amp? if so can you provied a link? many thanks!
sean
sean
Sean: Are you talking about for your car or boat? If for your boat if you locate the IPOD near your antenna it should work very well. One of the reasons that the FM Modulators do not always work so well is that the transmitter is very low power (so you do not interfear with other peoples cars). The transmitter needs to be located near the antenna as close as possible for best results. So in the case of most european cars with the antenna in the back or roof they some times do not work so hot. There are IPOD adaptors for lots of cars if you let me know what you are talking about then maybe I can see what is available for you.
Jon
Jon
Put your best foot forward!
Jeff - Mich.
Jeff - Mich.
I have the kenwood Head unit & music keg (MP3) in my boat it works up till 65 mph after that the G force knocks it out
Rick OSG
