One tach not working >
Old 01-03-2005 | 07:56 AM
Formula Outlaw's Avatar
Default One tach not working
The last time out (368 days ago according to the Cuda Count) I noticed my starboard tach would quit working, then come back, quit working, then come back. When I fired the motors off yesterday the starboard tach never moved. Obviously probably a bad connection or ground somewhere.
Where's the best place to look, I'm not sure where the tach wire would be at the motor, at the distributor? Anybody dealt with this before. I've got a feeling it's probably at the motor and not the dash.
Any ideas would be appreciated. Thanks. Russ
Formula Outlaw is offline
Old 01-03-2005 | 07:57 AM
offthefront's Avatar
Default Re: One tach not working
same one ....Starboard side ....you have to tap it on mine and it fires right up ....
offthefront is offline
Old 01-03-2005 | 08:00 AM
I tapped the drumbeat to "Wipeout" and it still didn't move.
Old 01-03-2005 | 08:10 AM
well fug ....post it on Tech ... this place is a Ghost town Lately ....Cuda's lost to the Biker Babes ....
Old 01-03-2005 | 08:24 AM
offshoredrillin's Avatar
I posted on the runnin thread russ, its usually tan on Chev, and runs from the dist. very easy to knock around, especially with all the work youve been doing on it....Rob
offshoredrillin is offline
Old 01-03-2005 | 08:27 AM
mopower's Avatar
Toxic FORMULA
Remove the face of the instrument panel. It should tilt back from the top. There are three wires on the tach. +12v , ground and ignition. Make sure you have 12v and ground. Easiest way is to put a volt meter across the two. If you have that , take a hand held tach/dwell meter and attach to the ignition lead and ground , if it works , it's a bad tach , if it doesn't , the troubles back toward the engine somewhere.
Still lost??? Give us the results and ask again.
mopower is offline
Old 01-03-2005 | 08:33 AM
HiPerf2000's Avatar
Check the connections on the top posts of your Coil. Hit them with some emery.
HiPerf2000 is offline
Old 01-03-2005 | 09:58 AM
jaybird's Avatar
I know this may sound stupid, but take it out for a couple of runs! When I bought my boat, many gauges didn't work, and I kinda freaked out a bit. My mechanic who has owned many Formulas told me that is common after sitting for long periods. My boat had sat for almost 2 years at that point. I didn't like that response, but after a couple good days of use, sure enough everything worked!
So you could try that, or start taking more things apart....
jaybird is offline
Old 01-03-2005 | 10:32 AM
This is true ....my star tach that I refered to tapping to get it to work seems to be pk now ......
Old 01-03-2005 | 11:06 AM
C_Spray's Avatar
Diamond Member #001
...Don't forget to check the big round connector where the boat harness plugs into the engine.
C_Spray is offline
