Help, Need for more speed - '05 Fountain 29 Fever HP500EFI >
Old 01-06-2005 | 11:31 AM
Default Help, Need for more speed - '05 Fountain 29 Fever HP500EFI
Last May I purchased my first offshore boat, a 2005 Fountain 29 Fever with a single HP500EFI w/ XR drive. I wish the boat had the HP525. Now that the warranty will soon be expiring, its time to make some modifications to the 500EFI. Without adding a supercharger (reliability is very important) what would you recommend. Note, I use the boat at Lake Tahoe 90% of the time, the rest is spent at the Sacramento Delta.
I have looked at Arizona Speed and Marine "Super Tuner Kit", has anyone had good performance enhancements with the tuner kit?
What about recommendations on a different prop?
xxxsive is offline
Old 01-06-2005 | 12:06 PM
Default Re: Help, Need for more speed - '05 Fountain 29 Fever HP500EFI
What speed are you currently running? Do you have a sportmaster gearcase?
SK-190 is offline
Old 01-06-2005 | 12:18 PM
When I took delivery of the boat at Lake Tahoe, the recall on the speedo showed 76 mph (factory test run). I have had the boat up to 61 at Tahoe and only 73 at the Sacramento Delta.
I don't know what gearbox I have.
xxxsive is offline
Old 01-06-2005 | 02:31 PM
I asked about the gearcase because I believe you might be getting close to the speed range where some hydrodynamic improvements my help you gain a few mph. But, there are a lot of variables that determine whether or not a nose cone will change much of anything.
It was just a thought, and I am by no means an expert.
How much speed were you looking to gain?
SK-190 is offline
Old 01-06-2005 | 04:07 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
That's all the speed you are getting?
US1 Fountain is offline
Old 01-06-2005 | 04:25 PM
throttleup's Avatar
mseeliger,
Can you post your :
WOT RPM
Speed
MPH
I have been working a few of these boats recently and I may be able to offer a little advice on your propeller and drive.
Julie
Throttle Up Propellers
727-531-2255
throttleup is offline
Old 01-06-2005 | 05:30 PM
Originally Posted by throttleup
mseeliger,
Can you post your :
WOT RPM
Speed
MPH
Julie
727-531-2255
WOT: approx. 5,000 RPM
Speed: 60-61 mph (lake tahoe)
Thank you for your help!
xxxsive is offline
Old 01-06-2005 | 07:34 PM
INDY27's Avatar
Go ahead and install a Procharger, I put a Stage II sc running 5-6 lbs boost on my 27 three years ago and have had no problems! Went from 71 to 86 on GPS with help from Julie & Matt of Throttle Up Propellors!
AUTOCONNECTIONLLC.COM
INDY27 is offline
Old 01-07-2005 | 07:16 AM
throttleup's Avatar
You need to run the HP500 at 5250 RPM at WOT.
What is the make and pitch of your prop?
Julie
Old 01-07-2005 | 09:10 AM
Julie
Julie,
I think the prop is a Merc Bravo 1 26 pitch (Lake Tahoe) and a 28 pitch for sea level.
Mike
xxxsive is offline
