where to buy JP1 jet fuel
Old 01-06-2005 | 04:42 PM
PorscheSpeed's Avatar
Default where to buy JP1 jet fuel
Anyone know where to pursache JP1 jet fuel in the ohio area?
PorscheSpeed is offline
Old 01-06-2005 | 05:11 PM
GLH's Avatar
GLH
Default Re: where to buy JP1 jet fuel
Airports?
Fuel Distributors?
GLH is offline
Old 01-06-2005 | 05:16 PM
CAP071's Avatar
For what use? I Buy high octance race car fuel from a local speed shop.
Aviation gasolines are leaded and not taxed as road fuels, either of which make them illegal for use on public highways. Aircraft engines are also essentially low engine speed, constant throttle applications that must work well at very low atmospheric pressure and temperature. Aviation gasolines are blended to work well only under these very specific circumstances, and do not perform as well under high rpm and high load applications.
CAP071 is offline
Old 01-06-2005 | 05:17 PM
CAP071's Avatar
contact Sunoco Race Fuels toll free at (800) RACE GAS (800 722-3427)to find a location
http://www.racegas.com/gt100locals/default.asp
CAP071 is offline
Old 01-06-2005 | 05:19 PM
Originally Posted by GLH
Airports?
Went to port columbus to try that ...... BAD IDEA turned into a clusterfukk and couldn't contact anyone who knew and couldnt get anyone to call back
Old 01-06-2005 | 05:22 PM
Went to a Goverment auction today at the US DSCC and bought a aircraft start cart. It has a small gas trubine in it as a motor to pover the gen. and compressor. I have evil plans for that little engine
Old 01-06-2005 | 05:42 PM
The Menace's Avatar
Any GA (general aviation) Airport will fuel it. Your a customer like pulling into a gas station. I fill mine there all the time. It has to be on the airport gorunds. I take the Cat (actually I store it there in a hanger).
PM me and let me know where you are at and I will find the closest airport with Jet fuel for you. In Fl they have a tanker service that comes right to your house or dock.
Any class B or C airports are out. Like COLUMBUS, Miami, Atlanta, Fort Myers International. You have to go where the private guys go.
I paid 3.80 the other day.
The Menace is offline
Old 01-06-2005 | 05:48 PM
Sonic30ss's Avatar
Isn't JP1 more like kero,diesel,or #2 fuel oil, than gasoline?? Not that a turbine can't run on gas.
Sonic30ss is offline
Old 01-06-2005 | 06:08 PM
yes they will run on diesel also
Old 01-06-2005 | 06:22 PM
Ted G's Avatar
JP is just filtered Diesel/Kerosene with some modifiers. In your app you can run Kero or diesel with no problem-depending on what you bolt it to
www.cbpba.com
Ted G is offline
