Modified Transoms >
Modified Transoms
Modified Transoms
Old 01-07-2005 | 01:27 PM
Prater's Avatar
Default Modified Transoms
Has anyone modified their transom to achieve better performance? If so lets see some pics. I am thinking of adding 12 inches to the transom to take the drives farthur back from the boat, I have to replace the transom anyways. Will this gain anything? Any input is appreciated. The boat is a 1979 Formula 255 Liberator with twin Bravo's.
Steven
Prater is offline
Old 01-07-2005 | 01:57 PM
Default Re: Modified Transoms
An extension box accomplishes what
your talking about.
JaayTeee is online now
Old 01-07-2005 | 02:00 PM
Prater's Avatar
Yes I know that, just wondering if anyone has done it different. Extension box is $1500 used times two gets pretty expensive. I am just looking for ideas before I start the transom work.
Prater is offline
Old 01-07-2005 | 02:13 PM
squick's Avatar
I guess that's one way to cure the 2 foot itus.
squick is offline
Old 01-07-2005 | 04:45 PM
mcollinstn's Avatar
outboard boats have been doing this forever,
build out the motor box, that is.
On an i/o I guess you can build out until you hit the oilpan on the notch.. Any more will require leaving the motors where they are and using a longer input shaft (like the Imco one).
Don't forget that you'll also need to extend the stringers all the way to the "new" transom, and you'll also need a new way to tie the corners together.
You'll spend a lot more than $1500 x 2 in time and sweat trying to do what you suggest.
mcollinstn is offline
Old 01-07-2005 | 04:53 PM
Exactly.
Old 01-07-2005 | 04:57 PM
Prater's Avatar
Thats the input I need, thanks for the help. Just figured while the transom and stringers were being replaced it would be a good time to do this if it were to happen.
Prater is offline
Old 01-07-2005 | 05:06 PM
IRONMAN's Avatar
look at the BAM marine site, he added a few feet to a cig
IRONMAN is offline
Old 01-07-2005 | 06:47 PM
prater who is going to do your transom and stringers?
JPD Motorsports is offline
Old 01-07-2005 | 07:23 PM
Prater's Avatar
Doing the work myself
Prater is offline
