Hot Water Transom Shower on 496MAG HO... >
Old 01-08-2005 | 11:15 AM
Nordicflame's Avatar
Default Hot Water Transom Shower on 496MAG HO...
Has anyone done this or is it even possible?
Thanks,
Dave
Nordicflame is offline
Old 01-08-2005 | 11:31 AM
mcollinstn's Avatar
Default Re: Hot Water Transom Shower on 496MAG HO...
what are you asking?
You looking for a way to plumb in a small water heater that uses engine heat? No problem. Very straightforward.
mcollinstn is offline
Old 01-09-2005 | 09:58 AM
So, nobody has a hot water transom shower on thier 496HO equipped boat?
Old 01-09-2005 | 10:08 AM
CMG's Avatar
CMG
you want to tap into the engine cooling water and bathe in it?? even if fresh water cooled motor, isn't it neccessary to cool the exhaust on way out?
Chris G.
CMG is offline
Old 01-09-2005 | 10:46 AM
Pantera1's Avatar
I belive its a small heat exchanger ..engine cooling water around a copper coil that has fresh pumped through it .. Try west marine or do a google , im sure it can be done
Pantera1 is offline
Old 01-09-2005 | 11:02 AM
MitchStellin's Avatar
I would think the water would be too hot off the exhaust. A heat exchanger with a pump would work but a shower bag in the sun is not too bad either.
MitchStellin is offline
Old 01-09-2005 | 11:46 AM
It wouldn't be too hot.. The regular ones come direct off of the drain cock on the block. It's cooled by mixing with the cold water from the lake. They both run thru the shower pump.
Old 01-09-2005 | 12:33 PM
mcollinstn's Avatar
Guys, it's a simple install. A small (2 gallon) marine water heater with a coolant loop in it. On a freshwater motor, just tap into the coolant loop to the heat exchanger on the uphill side of the tstat. Run it thru the coolant loop on the water heater. Dump it back into the system on the suction side of the circ pump.
The water heater will have the proper flow diagram.
On a sea water cooled motor, you plumb it differently but it still works.
Old 01-09-2005 | 12:54 PM
got one on my formula 31 ss twin 496
dreamer is offline
Old 01-09-2005 | 06:05 PM
Draemer,
any brand name on it?
THX
