Maxumus 5 blade / hering
Old 01-10-2005 | 11:30 AM
Default Maxumus 5 blade / hering
Which of the two props would you say are better and why
baja27 is offline
Old 01-10-2005 | 01:37 PM
Semper Fi's Avatar
Default Re: Maxumus 5 blade / hering
I never used either, but I have heard alot of unhappy customers with the service of Herring.
Semper Fi is offline
Old 01-10-2005 | 03:25 PM
ReggieRaft's Avatar
I have a 30 pitch maximus and I am very happy. Big gain in bottom and midrange. top end about the same as brovo.
ReggieRaft is offline
Old 01-10-2005 | 03:32 PM
Stormrider's Avatar
JC Performance Engines
How about stability?
And what are you running greg?
Stormrider is offline
Old 01-10-2005 | 03:33 PM
throttleup's Avatar
These props are very different from each other. The Herings are cleavers and induce stern lift and the Maximus has a round ear blade design inducing bow lift.
Julie
throttleup is offline
Old 01-10-2005 | 08:56 PM
mcraymond3's Avatar
Commercial Member
Commercial Members
Julie, you didn't mention the Hydromotive P5-X. Baja27 you need to call Julie, she knows props. Powerboat mag. even thinks so.
mcraymond3 is offline
Old 01-10-2005 | 09:35 PM
JCPERF's Avatar
Go 6 blade and stop the madness.
JCPERF is offline
Old 01-10-2005 | 09:43 PM
RollWithIt's Avatar
So that explains why my boat is faster top end with the cleaver prop vs the lobbed Mirage prop. I just figured it was due to available surface area to bite into the water and to effect rpms.
RollWithIt is offline
Old 01-10-2005 | 10:55 PM
Semper Fi's Avatar
Are you using 3 blade Mirage's? If so, what is your boat and specifics?
I have a 33' V with 29 Mirage 3 blades and I'm going to try 4 or 5 blades soon.
Old 01-10-2005 | 11:00 PM
RollWithIt's Avatar
I got a 88 Baja 240 sport. Factory 454 mag and running 23 pitch props. Both came with the boat. GPS with the Mirage 3 blade was 58.8 with two people and quarter tank of gas. Never did GPS test with the cleaver. Unknown make on it. But I know it feels faster at speed. Just takes a little longer to jump out of the whole. Something a 4 or 5 blade should help eliminate.
