Cutting High Pressure steering hose
try doing it like you would cut a braided line....you can wrap the line with some masking tape then you can use a hose clamp as a guide and cut with a hack saw.
-Wally
-Wally
Originally Posted by Boatally Insane
A chop saw or an abrasive disk in a die grinder.
Smokes a bit when going through the rubber but otherwise it works great!
Doug
Doug
Originally Posted by US1 Fountain
Be sure to flush it out REAL good after cutting.
Official OSO boat whore
I've been using some heavy duty electrical cable cutters. Slices right through and leave a clean square cut.
First cut it a half inch long then insert a dowel and cut again. This should give you a smoother cut as the shape is supported during the cutting process.
