Why mechanical fuel pumps on 1000+ hp? >
Old 01-10-2005 | 03:02 PM
Brad Zastrow's Avatar
Default Why mechanical fuel pumps on 1000+ hp?
Why do I see mechanical fuel pumps along with electric pumps on the bigger horsepower engines? I hear the comments that if the electric fails you can limp on the mechanical. My last setup with return lines the mechanical had no chance of flowing enough to run the system to feed 1000hp. My next setup will not have the mechanicals as I will not chance losing an engine if the pumps dies. I would rather have it shutoff then go lean.
Brad Zastrow is offline
Old 01-10-2005 | 03:44 PM
Default Re: Why mechanical fuel pumps on 1000+ hp?
I know of at least 1 rigger that uses primarily a mechanical pump and an electric kicks in if there is low pressure. They use a hobbs switch connected to the pumps output that turns on an electric pump at under 6psi. It is plumbed in parallel to the mechanical pump. The electric is there to augment the mechanical at top end, not replace it in case of failure.
Gary Anderson is offline
Old 01-10-2005 | 04:52 PM
Comanche3Six's Avatar
Thats what I do.
Comanche3Six is offline
Old 01-10-2005 | 08:01 PM
Infomaniac's Avatar
A good 6 check valve mechanical pump will easily support 1,000 HP when plumbed properly.
Infomaniac is offline
Old 01-10-2005 | 08:37 PM
mikes280's Avatar
i agree i have never had a problem with a mechanical pump keeping up with 1000
mikes280 is offline
Old 01-10-2005 | 09:16 PM
Am I correct that you guys running strictly mechanical are not running injected but carbs
zahndok is offline
Old 01-10-2005 | 10:44 PM
mr_velocity's Avatar
I almost run this setup, both pumps run all the time, mine is a Holley 1050 carb setup.
mr_velocity is offline
bwiencek
6
08-20-2008 10:07 AM
Andy
9
04-01-2008 04:25 AM
THRILLSEEKER
0
07-14-2003 08:47 AM
RLW
9
04-13-2003 03:58 PM
jagrlg24
8
02-11-2002 06:10 PM
