From stock exhaust to Gills >
Old 01-28-2002 | 06:35 PM
27 FOUNTAIN's Avatar
Post From stock exhaust to Gills
Took the boat out Sunday,(was 60 degrees in Ohio)ran the boat first time since installing a set of used gills with silent choice risers. 2 mph and 200 rpm, couldn't believe it,really didn't expect anything.We had exactly the same load of people as previous top speed(went from 79.1,@5400 to 81.1@ 5600) and similar temp, except water temp was quite bit colder.Boost really didn'y drop off like I expected, still 8 lbs at wot.I had been getting stories from different engine builders, some said didn't need exhaust w/blower some said it would add power.Next in line,maybe lab finish 23p Rev 4 and add a little pitch to get rpm down.
27 FOUNTAIN is offline
Old 01-30-2002 | 10:24 PM
Tinkerer's Avatar
Cool
I've been telling people for years that you will gain 200-300 rpm by adding good aftermarket exhaust. Had some guy telling me NO-WAY. They sure make a difference. If you don't have a problem with blowout in turns or coming on plane stick with the 3 blade prop it will be faster than a 4 blade. If you want to keep the same rpm go up 2 inches and have it lab finished.
Tinkerer is offline
Old 01-31-2002 | 06:53 PM
Post
Tried a 3 blade before, the boat won't even plane, just blows out before it breaks over. Unfortunatly,23p is the largest Merc makes at this time, and of all the props I've tested, I like the Rev4 the best.It may be possible to up pitch the one I have though.Will be checking into it.
Old 02-01-2002 | 10:51 AM
Luke_Chinewalker
Post
27fountain- what pitch prop were you spinning at 5600 rpm to get that 81mph speed?
is your drive ratio 1.36:1 or 1.5:1?
[ 02-01-2002: Message edited by: Luke_Chinewalker ]
Old 02-02-2002 | 11:27 AM
Post
Luke, Merc Rev 4 with a 1.36 drive. This prop seems to have a low slip factor,11%.
Old 02-03-2002 | 12:59 AM
SFOcean's Avatar
Charter Member #394
Post
27, I also run a 23" Revolution 4 with 1.36 gears. Had Chad Hill lab finish, pitch up, and add cup and rake for more bow lift. This worked, the rpm dropped about 300 or so and gave more lift to the nose adding 2 to 3 mph. I think you will like a pitched up lab finished rev 4.
SFOcean is offline
Old 02-03-2002 | 10:20 AM
Shooter's Avatar
Charter Member #300
Post
A question that I have yet to have answered is I have Gils, but with silent choice (switchable y-pipe). If I dump that, will taht increase speed? No one seems to know...
Shooter is offline
Old 02-03-2002 | 10:46 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
Post
Shooter, my boat was originally straight thru hull with Gils. I added silent choice last winter and it made absolutely no difference in speed for me. nuthin, notta, zero, zilch.
Jerry
US1 Fountain is offline
Old 02-03-2002 | 11:23 AM
Post
SFO, What kind of boat are you running the Rev 4 on, have you tried other props.This prop works the best for me and would like to continue to use it.Some prop shops want to steer me towards the Bravo 1 which I would like to try.
Old 02-03-2002 | 09:45 PM
Nabber
Post
As a comparison, I ran a 22 Bravo1 on my Imco 2" shorty and only ran 63. With my Rev4 23" I run 67. Great prop.
