Steering Hub
Can anybody identify this steering hub? Its on an 88 Cigarette Bullet. I'm
trying to adjust it because it is slightly slanted to the right. It
seems to be a two part hub and the bottom part is the part that seems
to be off center. I wanted to know the brand so I can
find a diagram of how they are attached. Any info will be helpful.
Looks like what I just removed from my Fountain. The AL piece with the socket head cap screws is attached to the steering mechanism by the 3 cap screws shown. The piece that you show with the angle is sandwiched between these pieces and is most likely part of the fiberglass molded dash. I may be wrong about how the structure is done but it looks like you will have to fabricate shim plates to go on either either side of the structure to straighten the steering shaft.
