Reclibrate ECU >
Reclibrate ECU
Reclibrate ECU
Old 01-12-2005 | 07:51 PM
Default Reclibrate ECU
I have a 454 mag EFI which I have changed the exhaust system from stock to Eddie marine thunder system and stock flame arrestor to a hardin marine XS serries. Do I need to have the ECU re-calibrarted, if so who would you recommend.
double deuce is offline
Old 01-12-2005 | 08:10 PM
Vinny P's Avatar
I hate the winter!!
Default Re: Reclibrate ECU
I had the same motor with the same mods. I found that adding an adjustable fuel pressure regulator took care of the slight lean condition that the aftermarket exhaust caused. There is no need to re-map the ecu. Just bump up the fuel pressure a couple of pounds to about 43#. I also had an MSD6m-2.
Vinny P is offline
Old 01-12-2005 | 08:12 PM
'05 Concept SF23
You should not have to have your ECU recalibrated. If your transom had some black on it you should have a cleaner transom now. Murc builds these motors rich anyway.
f311fr1 is offline
Old 01-13-2005 | 09:18 AM
Strip Poker 388's Avatar
Rob
I would call Mark at http://www.precisionmarine-efi.com/ and see if it needs a reprogram. He will be honest with you and helpful over the phone .
Rob
Mark
Phone: 504.469.7463
Fax: 504-469-7418
Email: [email protected]
Strip Poker 388 is offline
dmueth
06-20-2007 01:31 PM
unbroken
6
12-10-2006 06:17 PM
Donzi502
4
10-03-2006 10:50 PM
seamate
1
11-19-2004 01:38 PM
Pat McPherson
10
05-14-2004 04:58 PM
