trimtab switch location? >
Old 01-14-2005 | 12:32 PM
Default trimtab switch location?
where is a good place for trim tabs switches? Right now there on the gunrail next to the throttle. I was thinking of putting them on the left side of the streeing wheel on the dash pod. Any ideas? TIA
88 MACH 1 is offline
Old 01-14-2005 | 01:40 PM
Default Re: trimtab switch location?
I'm assuming your dash is on the starboard side on the boat. I was going to move mine but thought it best to keep on the same side of thottle. This way I didn't have to move my right hand to the wheel and left hand to the switches. Keeping it with the thottles meant I could let go of the thottles, adjust tabs, and get back to the thottles quicker.
CN24 is offline
Old 01-14-2005 | 01:45 PM
Wally's Avatar
Were doomed!
i would keep them close to the throttles if you can. If you have hyd steering then maybe i would consider it.....but if you dont then you will have to take you throttle hand off the sticks to grab the wheel and then use your left hand to work the switches.......last thing you need is a situation to pop up on ya and have to switch hands back to try and grab the sticks!!!! This way atleast one hand is always on the wheel while the other is not too far away from the throttles
Idealy if you have the room to move them i would try and place them right above the throttles so all you have to do is move you hand forward a few inches to reach the switchs...
-Wally
Wally is offline
Old 01-14-2005 | 01:49 PM
fund razor's Avatar
I'm with these guys.
Been using my throttle hand too long.
Like to leave my left hand on the wheel. I use it as a grab handle.
fund razor is offline
Old 01-14-2005 | 02:33 PM
Dave M's Avatar
Veteran: Navy
Here's mine.... Seems to work well. I use the throttle hand for the tabs.
Dave M is offline
Old 01-14-2005 | 07:58 PM
Maybe I'll try behind the throttle, all you have to do then is drop your hand back off the throttle and trim and right back on the throttle........hmmmm?.....
Old 01-15-2005 | 07:33 PM
you have one for sale at trick marine? can't see the pic need to upgrade
Old 01-16-2005 | 08:05 AM
fund razor's Avatar
The joysticks look cool.
One of us could email you the pic if you want.
Old 01-16-2005 | 09:43 PM
Fred will be sending one Monday Thanks
Old 01-17-2005 | 12:46 AM
I guess with all the free advice he's getting, he could buy a membership and see the pics
Griff is offline
