cam card
Old 01-18-2005 | 08:58 AM
Default cam card
anyone have specs.and timing card of a Ultradyne 284/292 HR12 HR14/HR15 ?
thank you!
awesomerott is offline
Old 01-18-2005 | 09:19 AM
rmbuilder's Avatar
MarineKinetics
Default Re: cam card
awesomerott,
Is this a new Ultradyne (Bullet Cams), an older UD when Harold Brookeshire had the company, or the Lunati version of the Ultradyne line?
Bob
rmbuilder is offline
Old 01-18-2005 | 09:44 AM
GPM
thank you!
I don't have a card but here are the specs, 284/ [email protected] 150@ .200 .575 lift.
292/242@ .050 160@ .200 .600lift.
GPM is online now
Old 01-18-2005 | 09:48 AM
I can't tel you Bob.
the boat is a 1999 and motor Gen v1
the cam is stamp as UD 284/292 HR12 HR14/HR15,also there is a I orT 5266 .
the UD is writhen by hand.
Old 01-18-2005 | 09:55 AM
Originally Posted by rmbuilder
awesomerott,
Bob
I did a lift check with out a degree wheel before i pull the cam out,came up with approx .356 int. 357. ex. on the cam.
Old 01-18-2005 | 10:25 AM
awesomerott,
Bob
I when at the shop to get the cam and double check and i was wrong about stamped #'s,it is all hand wrighting with a engraving tool.
the back end of the cam have stamped #'s 8 98 L or Z (more likely a L)
sorry if i misinformed you!
hope this will bring some light. JP.
Old 01-18-2005 | 10:52 AM
rmbuilder's Avatar
MarineKinetics
Awesomerott,
Here is the information on that cam;
284*/292*
230*/238*
112* LSA
108* ICL
.3533"/.3533" lobe
.601"/.601" valve w/1.7 rockers
The HR14 is the master lobe number for the intake
The HR15 is the master lobe number for the exhaust
The I/T 5266 is the serial number
Bob
Old 01-18-2005 | 10:56 AM
thank's much appreciated!Bob
Old 01-18-2005 | 11:46 AM
Awesomerott,
284*/292*
230*/238*
112* LSA
108* ICL
.3533"/.3533" lobe
Bob
is it a old UD or bullet or lunati?
Old 01-18-2005 | 11:57 AM
do you also have the seat timing ?
