Aftermarket exhaust for Carburated 502s
Tons of stuff out there. I can hook you up on Lightning Stainless Steel Headers. I run them on my own Fountain and love em. There are lots of other systems available.
Shoot me an email or call and I'll get you a good price on what you need.
Fionn(Finn)
510.5418124
[email protected]
Fionn(Finn)
510.5418124
[email protected]
my frends 96 35 is going to dicth some stoct stoof , like water serluking pump stock manafolds sparkarester and reprogam the chip i dont know, maybe 95 to 105 hp gain. 1 28 04 it will be neet to see whalt happens ill ceep you posted
alpine99, make sure you check your motor On-Center dimensions. Then, make sure what you're buying works with those OC numbers. Measure between the leading edges of your drive skegs, and this will give you a good number.
My 10-Meter is 33" OC, and this limits me as to what exhaust I can run due to space between the motors. I run Imco Powerflow's, and I have maybe a 1/2" between the manifolds.
Most of the nice big-tube stuff requires 35" OC.
Good luck,
Brian
Good luck,
Brian
