Air Brushing >
Air Brushing
Air Brushing
Old 01-29-2005 | 11:12 PM
Default Air Brushing
I was wondering on when a boat is air brushed do they usually clear coat just where it is air brushed or is the whole area of the air brushed area clear coated to a seam in the boat etc.
I was wondering for repair reasons.
Thanks in advance.
Active Mike is offline
Old 01-30-2005 | 11:11 AM
mcollinstn's Avatar
Default Re: Air Brushing
you can do spot clearcoat. There is a flashing agent that you spray on the transition line between new clear and old clear that "flash melts" the clear into each other.
mcollinstn is offline
Old 01-30-2005 | 11:33 PM
mcollinstn,
Thanks fore the feed back. I plan on having some work done on the boat this winter and was wondering how it was done.
Old 01-31-2005 | 06:23 AM
offshoredrillin's Avatar
I also have covered many with 3M paint protection film, I have protected many murals on bikes and cars, even fire trucks. its 99.9% clear and 100% UV compatible.
offshoredrillin is offline
Old 01-31-2005 | 07:24 AM
Steve_H
do you have a name for this product and where to buy it?
Old 01-31-2005 | 10:17 AM
KNOT-RIGHT's Avatar
Call any automotive body shop supply store. Dupont makes it as well as PPG
and Sikkens it is a Clear Coat Blender. It allows the new clear to melt and flow into the original. It is helpful to know what is the original finish on the boat. Personally
I would try to find areas to hard mask. If not the above will work.
Good luck with your project/ repair
Gerry
KNOT-RIGHT is offline
Old 01-31-2005 | 10:49 PM
Thanks again guy's.
Old 02-01-2005 | 07:54 AM
All air brushing has to be protected. Most time it is only laquer clear,its easier to deal with. Top notch jobs will use urethane clear to an edge, this will eliminate any problems in the blending process. ALL jobs that are blended will soon or later show. Its the nature of the beast
jsmagnum is offline
Old 02-01-2005 | 10:32 PM
So is the clear coat just sprayed on up to the outline that is airbrushed or is it sprayed over the painted area and onto the unpainted?
Also pro's and con's with air brushing compared to decals.
Old 02-04-2005 | 04:31 PM
my entire boat was repainted with black 2 part urethane, and airbrushed, then two coats of clear in 1998. it is still holding up quite well and i don't wax it at all. just hose it off unless seagulls get it. i've touched it up several times. sand down through the clear, re-do the base, air brush, and use regular clear over the repair, the edges where the repair meets the old gets cleared with blender clear. there is polishing and wet sanding involved too. you need to be a bit artistic to blend the areas correctly. it's not easy.
if you only clear over one spot that has been air brushed, it will not look right. it will be very shiny, thus, the whole area should be cleared such as the transom.
my opinion is, air art is favorable over vinyl. it's not as as to repair though.
excaleagle42 is offline
