454mag rebuild in progress >
Old 02-03-2005 | 08:43 AM
Stormrider's Avatar
JC Performance Engines
Default 454mag rebuild in progress
Alright, well I've got enough to start posting pics of the rebuild.
Jeff from JC Performance is doing the work.
The block is original mark IV, bored 30 over and decked.
It needs a bit more sanding at the cylinder openings, otherwise ready to go.
Attached Thumbnails 454mag rebuild in progress-dsc00269.jpg   454mag rebuild in progress-dsc00270.jpg
Stormrider is offline
Old 02-03-2005 | 08:45 AM
dykstra's Avatar
Default Re: 454mag rebuild in progress
looking great
dykstra is offline
Stormrider's Avatar
The heads are new dart iron eagles.
Jeff still needs to clean up the ports to get them to flow better.
Attached Thumbnails 454mag rebuild in progress-dsc00266.jpg   454mag rebuild in progress-dsc00267.jpg   454mag rebuild in progress-dsc00268.jpg
Old 02-03-2005 | 08:49 AM
Stormrider's Avatar
Pistons are new & shaved. Connecting rods are original, but redone and cleaned up, new ARP bolts.
Attached Thumbnails 454mag rebuild in progress-dsc00264.jpg   454mag rebuild in progress-dsc00265.jpg
Old 02-03-2005 | 08:51 AM
Stormrider's Avatar
Crank is original, and has been rebalanced.
Attached Thumbnails 454mag rebuild in progress-dsc00262.jpg   454mag rebuild in progress-dsc00263.jpg
Old 02-03-2005 | 09:11 AM
What are you putting into it and what kind of power do you expect? What boat is it going into?
CN24 is offline
Old 02-03-2005 | 09:32 AM
Stormrider's Avatar
This is for my 1995 Pantera 24SE.
Everything besides the block, conn. rods and crank will be new.
Will be putting a hotter cam in, 850holley carb, new intake, stainless marine exhaust. Expecting around 550hp. This will be dynoed.
Hopefully Jeff will chime in to answer these questions better.
Old 02-03-2005 | 09:37 AM
Stormrider's Avatar
These are the 308s, and compression should be around 9.3.
Had to replace my oringinal large rectangular ports since one was shot, so Jeff suggested these. And I know the originals are too big for marine use.
Old 02-03-2005 | 09:53 AM
what drive do you have and what is your dimension from the prop shaft to the pad?
CN24 is offline
Old 02-03-2005 | 10:04 AM
Stormrider's Avatar
I know my X dimension is around 17 1/4".
I currently have a bravo one, but I'm thinking of changing to an XR upper.
