difference's in engine blocks >
Old 02-03-2005 | 10:47 AM
Default difference's in engine blocks
What's the difference between the generation of the BBC's and how do you tell between them?
CN24 is offline
Old 02-03-2005 | 11:04 AM
magnum27's Avatar
Default Re: difference's in engine blocks
All I know is a gen 6 does not have a location for a mecanical fuel pump on it. It has to have an electric pump feed it gas.
magnum27 is offline
Old 02-03-2005 | 12:22 PM
Stormrider's Avatar
JC Performance Engines
Carm, try to pick up a copy of "Big Block Chevy Marine Performance" by Dennis Moore. There is plenty of good info there.
Here are a few pages that may help.
Attached Thumbnails difference's in engine blocks-page1.jpg   difference's in engine blocks-page2.jpg
Stormrider is offline
Old 02-03-2005 | 01:10 PM
Stormrider's Avatar
pages 3 & 4
Attached Thumbnails difference's in engine blocks-page3.jpg   difference's in engine blocks-page4.jpg
Old 02-03-2005 | 03:30 PM
Gen IV... tried and true "old school", more or less unchanged since the 396 in '66
Gen V Same Geometry as gen 4, but slightly different ballancing to accomodate one piece rear seal design, started in 1991, early gen V engines had normal provision for mechanical fuel pump block still made in Tonowanda NY, also has oiling differences.
Gen VI, really unchanged from the Gen V, but has a roller lifter cam, was made in Tonowanda untill GM sundowned it for production use, then tooling was moved to Mexico (tolluca?), still made to this day as replacements through gm's service parts division, but not sold to OEM's.
Sadist is offline
Old 02-03-2005 | 08:57 PM
Easy checks:
Gen IV...place for mechanical fuel pump
Gen V....No place for mechanical fuel pump
Gen VI...No place for mechanical fuel pump and non-steel timing chain cover.
Edward R. Cozzi is offline
Old 02-03-2005 | 08:58 PM
storm thanks for the info about the book. true is I have it, maybe I should read it!
CN24 is offline
Old 02-07-2005 | 05:48 PM
gen 4 place for mechanical pump
gen 5 no place for mechanical pump
gen 6 place for mechanical pump and aluminum timing chain cover.
i'm using 1 gen 5 and 1 gen 6 . gen 5 uses mechanical fuel pump mounted on seawater pump and runs off crank via belt. spins twice as fast. as gen 4 mech pump that runs off of cam . gen 5 and 6 use one piece rear main.
javx2 is offline
Old 02-13-2005 | 07:25 PM
50boat's Avatar
also the water pasages are difernt ,, round and kindia triangle shape,, the check the book for inner change for shoure
50boat is offline
Old 02-14-2005 | 01:19 PM
tomas_wallin's Avatar
I just bought that book last week - I spent almost too many hours reading it back and fourth
tomas_wallin is offline
redcorvetteman3
Wanted
4
05-15-2008 08:08 AM
Sulfur1
04-28-2008 02:48 PM
Sulfur1
7
12-11-2007 12:01 AM
f311fr1
03-13-2005 12:47 PM
badbug
2
01-08-2002 01:29 PM
