Corsa Wiring diagram
I wish PQ would of used that diagram when they built mine. They didn't see any reasonn to use the relays and breaker. Just a normal gauge wire from the dash switch to the solenoid.
You would turn on the choice and all the gagues and acc would drop way off! I rewired and did it the same as above using one 30amp relay per two solenoids that works just as well.
I have Steps & Bubbles!
oops. i just NOW got around to looking at the diagram and printed it out.
That one is for the OLD style diverters with 2 wires from the solenoid. I have the New ones. With 4 wires coming from the solenoid. You wouldn't happen to have a diagram of the new ones would you?
