A New Style Fuel Pump >
Old 02-13-2005 | 09:17 AM
Strip Poker 388's Avatar
Rob
Default A New Style Fuel Pump
Here's something new I figured Id show ya . Stewart does a lot of Nascar stuff. Big claims.
Maybe this will give me 1 1/2 MPH
Strip Poker 388 is offline
Old 02-13-2005 | 11:12 AM
KNOT-RIGHT's Avatar
Default Re: A New Style Fuel Pump
200-3000hp. Serious. Whats the gph? Looks like #10 in # 8
out. How much is that unit? No Diaphragm rupture.
KNOT-RIGHT is offline
Old 02-13-2005 | 12:44 PM
Currently only available for small block. Sweet pumps.
NOBODY is offline
Old 02-13-2005 | 02:25 PM
ratman's Avatar
mark from mer has been talking with them and they are now tooling up for a big block pump...i hope they have em done in time for my motors...
ratman is offline
Old 02-13-2005 | 03:32 PM
RMPRam's Avatar
I spoke with Howard Stewart last week about seeing if his BBC prototype pump would work with an Eikert 3 stage sea-pump.
He was kind enough to send me 2 prototype BBC pumps to check. On my application, a Merlin block with a 3 stage Eikert sea-pump, Howards prototype would not clear the Eikert pump. I removed the 3 stage Eikert and bolted on a stock Mercury single stage sea-pump and his fuel pump has no problem clearing.
His fuel pump appears to be a quality piece and I wish I would have been able to use it in my application, PSI supercharged BBC motors using a modified Holley 6 valve block mounted fuel pump for cruise and a Weldon electric, hooked to a hobbs pressure switch to engage @ 4lbs. boost for top end.
I believe that his pump would do, what it took me 2 pumps to achieve. Time will tell.
RMPRam is offline
Old 02-13-2005 | 03:44 PM
KNOT-RIGHT's Avatar
This link belongs in Uncensored http://www.racepumps.com/tech.html
Old 02-13-2005 | 04:15 PM
Rob
It looks like its a good Idea.Alittle pricey but it would be cheaper than a electric pump or how RMPRam is talking about 2 pumps,So its looking to be cheaper in the long run
I guess Howard is not making his water pumps anymore.
Caveman everything is not about sex but I think it got sutphen30 excited .all that pumping action
Rob
BillR
11
07-29-2022 06:31 AM
BillR
27
08-10-2008 11:31 PM
MILD THUNDER
Wanted
1
04-06-2008 10:57 AM
jdub
7
03-26-2007 05:06 PM
