Msd Advance Curve
I am going to be installing an MSD distributor on my modified 454. How would I go about selecting a centrifugal advance curve. MSD shows a few graphs of the various curves achieved with different spring combinations, but how do you determine what curve will perform best.
Also, how many degrees of total advance do you guys use or recomend.
454 CI
MSD box
Med rise dual plane manifold
8.8/1 compression
hyd roller cam:
duration @.50 IN-224 / EX-224
max lift IN-.566 / EX-.566
lobe sepperation 112 degrees
89 octane
5000-5200 rpm
454 CI
MSD box
8.8/1 compression
hyd roller cam:
89 octane
5000-5200 rpm
Registered User
I don't have my MSD graph handy but one thing to keep in mind is that reguardless of which curve you use you'll be at full advance at about 2800 rpm. Not much more than it will take to be on plane. I run the weakest springs for 32 total at about 2400 rpm.
The beauty of the MSD is the fact that it's so adjustable you can custom tailor your advance curve for any application.
If you want the ideal initial setting at idle, just hook up a vacuum guage under the carb and advance the timing until it pulls the most vacuum. Note where your timing is now at.
From the specs you've posted I'd say your motor will run the best at 34* total. Pick the lightest springs so all your advance will be out by 2500.
Now you need to select an advance-limiting bushing. Just deduct the amount of initial timing from your total advance. This figure will be your ideal amount of advance for your motor.
Example, if your motor pulls the most vacuum at 18* and your total is set at 34* you need to pick a bushing that will allow 16* of advance.
Just my .02
Kurt
Just my .02
Kurt
I agree with Biggus, You want to have an initial timing your motor will be happy idling at in gear(and start), and then have the total advance limited to your WOT total your motor is happy with. Most boat motors go from idle to 3000 just to get on plane, and usually don't drop below 2800 once on plane, so as long as all the advance is in by 2800 to 3000 your good to go.
Example
12 deg initial 34 total by 3000 RPM (22 deg advance)
or
16 deg initial 34 total by 3000 RPM (18 deg advance)
Example
or
RLW nothing wrong with running a dist locked out in a boat as long as you have a start retard. The RPM comes up so quick in a boat (especially ones with high HP) and usually never drops below 2800 so your advance is always in anyway. But sometimes makes the carb hard to adjust at an idle with that much initial.
I have the ability to have the start retard or not. I run the MSD Digital 6 Plus.
I have experimented in both "modes".
I presently run fully locked with a 9.2:1 comp ratio.
Carbs have always been Nickerson 1050's. I have never needed to make any adjustments on the carb but see your point and it makes sense.
Russ
Russ
Ran blown 540 w/ single 1050 dom MSD 6/mallery setup all last summer - I only ever checked total advance, and didn't notice till summer was over that dist. was set for only 5-6 degrees cent. advance (might as well have been locked) - so my idle advance was at 27-28 deg. - Shocked the hell out of me, but it idled great at 750rpm and had no starting issues.
