Sirius Antenna >
Sirius Antenna
Sirius Antenna
Old 02-14-2005 | 04:14 PM
MiamiVice's Avatar
Default Sirius Antenna
How have you guys mounted your satelite radio antennas. I have a 32 fountain fever and was wondering the best place to drill a hole , or better yet any pictures of custom made brackets instead of drilling a hole.
MiamiVice is offline
Old 02-14-2005 | 04:35 PM
Smitty's Avatar
Default Re: Sirius Antenna
YIKES!!!!! You do not need to drill a hole !!!! I called the local stereo shop and they recommended placing it in the cabin somewhere so it is directly under the deck in an area where it is all fiberglass above. The signal goes right thru the glass. I did it and it works fine. I made a small brkt and it is tight against the ceiling belowdecks.
PUT AWAY THE DRILL !!!
Smitty is offline
Old 02-14-2005 | 04:46 PM
MiamiVice's Avatar
Thanks man, I did not want to drill a hole. I can hide the antenna in the space behind my stereo. You said place it up against the glass? I have the Shakespeare Sirius SRA-30. Its a small dome about 3" dia.
Old 02-14-2005 | 04:47 PM
Poorsche's Avatar
I've got XM but same theories apply--my antenna is on a shelf in the cabin and it workd great. Get full signal stregnth almost everywhere. I've got antenna in my cars on dash--both work great. Don't bother with a fancy installation.
Poorsche is offline
Shorgasm
06-20-2006 11:54 AM
