EMI Thunder Cast Riser VS SS Riser >
Old 02-18-2005 | 02:29 PM
Whiteknuckle's Avatar
Default EMI Thunder Cast Riser VS SS Riser
Currently I am using EMI cast risers with Corsa diverters. I want to eliminate the Corsa's and I expect the aluminum cast risers may be a source of restriction on this otherwise decent exhaust. Has anyone changed from the cast to SS risers? I also do not care for the water passage through the risers and that can be eliminated with the SS style. Is it worth $800.00 to make the change?
Whiteknuckle is offline
Old 02-19-2005 | 08:56 AM
dyno's Avatar
Charter Member #655
Default Re: EMI Thunder Cast Riser VS SS Riser
Good Question! I'm going to change over soon.....going to have custom risers made, its cheaper than buying from EMI.
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 02-19-2005 | 10:07 AM
Dyno,
Please keep me informed of your progress on your custom risers. I have been considering for a couple of years of making my own risers. It's just a matter of finding the time for this and the rest of life's demands. Although I have no proof, I suspect those cast risers on not getting the job done. Right now we are in the middle of "version IV" of my engine. I wiped out a cam lobe after about 125 hrs on it last fall. We have the engine totally apart and doing some more changes. I just can't help myself.
Larry
Old 02-19-2005 | 12:14 PM
boatn70's Avatar
let me know what you guys come up with, i have the alum. risers going onto my motor, just wonder what gains you see when you make the change.
i really dont want to go from corsa to just mufflers. i really like the silent part alot...........it makes my wife happy!!!!
boatn70 is offline
Old 02-19-2005 | 04:53 PM
dyno's Avatar
Charter Member #655
It wount be an apple to apple comparison becouse I'm going to roller cams too,but I'll keep you posted on costs and results.
Don
dyno is offline
Old 02-19-2005 | 05:34 PM
if anyone needs a set or 2 of the EMI aluminam riser in 4 inch I have them.used for 1 hr but the cams where 2 big and had water reversion problems so I went totaly dry.hose is long enough for trs application.
z.zuperboat is offline
Old 02-20-2005 | 08:34 AM
boatn70's Avatar
z.z, your talking just the riser correct?? not the manifolds?
kevin
boatn70 is offline
Old 02-20-2005 | 03:58 PM
z.z I am looking for a set of manifolds and risers.
You can e-mail me @ [email protected]
BOATING ON A BUDGET is offline
Formula Outlaw
05-20-2018 04:56 PM
bcfountain
2
08-21-2008 07:01 PM
DMAX
3
05-08-2006 04:29 PM
Danny_Ocean
1
04-20-2004 05:22 AM
TwoKs
8
06-16-2002 04:04 PM
