MO Boaters, Who's your marina? >
Old 02-19-2005 | 03:25 PM
ctadams21's Avatar
Default MO Boaters, Who's your marina?
TIme to replace valvesprings on HP500s and I am not wanting to tackle it myself. Who do you guys recommend in the St. Louis or LOTO area?
Anyone use Competition marine in St. Charles?
CTA
ctadams21 is offline
Old 02-19-2005 | 03:26 PM
Outlawcowgirl's Avatar
Transplanted to KS
Default Re: MO Boaters, Who's your marina?
I used a guy in Blue Springs. Get with Gordo and he knows the guy.
Outlawcowgirl is offline
Old 02-19-2005 | 03:36 PM
KCHOTBOAT's Avatar
Charter Member #737
bilgerat a member here who owns Lake Shores at around the 8mm.
KCHOTBOAT is offline
Old 02-19-2005 | 03:45 PM
ctadams21's Avatar
cool guys, thanks for the info. What can I expect to pay for valvesprings replaced? 1K per engine?
Old 02-19-2005 | 04:12 PM
Transplanted to KS
I had the works done on my 525 and I paid a little over $900.00.
Old 02-20-2005 | 02:52 PM
mpally's Avatar
Advanced Marine @ LOTO is who we use.
mpally is offline
Old 02-20-2005 | 04:46 PM
gene lightning performance
573-374-7974
Bad to the bone is offline
Old 02-22-2005 | 09:26 PM
ctadams21's Avatar
I've heard good things about Advanced. Where are they? Close to the dam?
Old 02-23-2005 | 01:23 PM
Gordo's Avatar
Charter Member #94
CTAdams,
Do you live in the St. Louis area? If so, I don't know anything about local folks for you. You have already heard some of the top names at the lake. The top of the list would be Rueben at CPR. NOT cheap, but lots of experience. A VERY close second, (arguably first for engine work) would be Gene at Lightning Performance. LOTS of experience, Not cheap, but knows motors. Not far away would be Jason and Mike<?> at Lakeshores Marine. They may not have the mega years experience but have been playing with a lot of high performance horsepowere, (including blowermotors), for the last 15 years or so. Jason has won his class in the Shootout the last few years in a ProCharged 33 Scarab that they built and continue to play with. These guys would probably be the most reasonably priced and as all the above, would stand behind their work. I've replaced my own valve springs a couple of times. The job may not be brain surgery but can screw things up bad if you don't know what you're doing. If you are closer to the KC area than St. Louis, get with me and I can set you up. Otherwise, you can't go wrong with any of the previously mentioned.
Abby-someone
Gordo is offline
Old 02-23-2005 | 01:52 PM
ctadams21's Avatar
Thanks for the info Gordo. I am closer to St. Louis than KC. I've actually rebuilt several engines but I just don't have the time or patience to do the job correctly in the tight quarters of my bilge. The last thing I want is to pack up the family, go the the lake and find out that I did something wrong and have to work on the boat all weekend. So I will be looking into some of your suggestions.
Thanks again everyone,
CTA
