496 HO manifold restrictor plate removal?
In past threads Raylar has mentioned that the 496 has a restrictor plate between the manifold and riser which would free up 15-20 hp by simply removing it. Has anyone checked into this and actually removed it and if so, what's involved? This to me seems like a fairly simple task to let the 496 flow better and even sound better... What are the pros and cons? I'm bored waiting for spring and need something to do...
Sounds too easy. Why would Merc put them in there if all it did was lower your HP? I thought I read somewhere on OSO that someone removed them with no positive results.
i think it was just on the 01 496's after that year they dont have the restictor plate ,I have an 01 thinking about doing it in the next week or so,will let u know what i find out.
Originally Posted by Harper220
If you get to it before I do, let me know what you find? I have a 2001 Daytona, so I don't know if the motors are 2000's or 2001's? Actually theres a sticker on the PCM 555 ecm that says 2002, which doesn't make any sense to me. Good luck
I don't know if you will notice any significant improvements by removing them. I did help a friend install a Whipple on his 2001 2 years ago and the instructions had us take them out. He has no problems because of removing them.
10 or 15 horse is about 1 or 1.5 mph depending on the hull
