Bravo XZ or Bravo I, How can I tell? >
Old 02-23-2005 | 09:09 AM
Harper220's Avatar
Default Bravo XZ or Bravo I, How can I tell?
I'm not sure which drives I have? Bought boat used from Eliminator dealer and was told it had XZ drives. No where on them does it say XZ or Bravo I... How do I tell what's what? Are there numbers or something else I could look for?
Harper220 is offline
Old 02-23-2005 | 09:29 AM
Default Re: Bravo XZ or Bravo I, How can I tell?
their is a blue ring behind the prop, on the xr also larger prop shaft. just call merc. with the serial # they can tell you.
customryder is offline
Old 02-23-2005 | 11:07 AM
rws's Avatar
rws
The XR and XZ have the same lower with the 1 1/4" prop shaft and Blue "Ring".The serial # will tell the tale.You can also remove the top cap and if it has straight cut gears it is an XR if the gears are helical((((((( kind of rounded then it is probably an XZ.
Rob
rws is offline
Old 02-23-2005 | 01:23 PM
Harper220's Avatar
I went and looked. I've got the blue ring and measured the shaft at 1 1/4". Don't know if it's xr or xz though. I'll call in the serial numbers.
Dave1972
6
03-30-2009 04:06 PM
1BIGJIM
Drives and Lower Units
3
06-10-2008 12:46 PM
PARADOX
0
02-27-2008 02:31 PM
articfriends
1
07-30-2006 08:10 PM
rslick
13
06-15-2005 11:54 PM
