blueprinting >
blueprinting
blueprinting
Old 02-24-2005 | 07:56 PM
dsandman6's Avatar
Question blueprinting
how much speed can i expect if i have my hull bluprinted on a 25 outlaw and is this something i can do with asander and level or is that a big mistake !
dsandman6 is offline
Old 02-24-2005 | 08:18 PM
crayolacrazy's Avatar
Default Re: blueprinting
when you blueprint sometimes you remove 90% of the time you add where are located lake way .atica ohio Kevin worked baja he,s good does alat race boats
crayolacrazy is offline
Old 02-25-2005 | 06:05 PM
Ironmanwb's Avatar
I think what Bobby was trying to tell you is to Call Kevin Brown at Lakeway Boat Repair in Attica Ohio. He worked at baja for 18 years and now he has his own glass shop. He has worked on boats suchas Twisted Sticks, Twisted Chicks and the 2003 F1 Single engine class Champion's boat. He is very good at what he does. Tell him that Aaron sent you.
Ironmanwb is offline
Old 03-03-2005 | 12:44 PM
FX10's Avatar
sandman,
Blueprinting should be left to a professional. It's not something you do with a sander and level. It's alittle more involved then that. There are different types of blueprinting, all of which depends on the attitude your looking for in your hull. One way is to true the bottom. Which is nothing more then taking a long flat board sander. Then you can also have steps altered by cantering the angles of the steps to achieve more bow lift. Anyway, the basic flatboard job usually runs about $ 1,500.00. Major modifications on the hull can cost upwards of $ 6,000.00.
I've been building, blueprinting and repairing offshore boats for over 30 years, so believe me. A nice blueprinting job can give you some MPH. But it costs.
Rick
FX10 is offline
Old 03-03-2005 | 02:46 PM
Dock Holiday's Avatar
Charter Member #34
Bobby,
you are going to have to stop drinking and typing at the same time!
Dock Holiday is offline
Old 03-03-2005 | 05:37 PM
Ironmanwb's Avatar
Originally Posted by Dock Holiday
Bobby,
I agree Dock....I think the marble he lays has gotton inside his head.
Old 03-03-2005 | 07:45 PM
dsandman6's Avatar
Rick thanks for responding the boat has a 385 hp so i realize it only going to do somuch I am looking for top end everything else about the boat im happy with what do think is better to do the hull or should i just whipple it and how long would it take to have the hull done thanks Sandman
Old 03-04-2005 | 10:09 AM
SSComp's Avatar
Kevin once called my boat Christine. Everytime he thought it was done it would come back wanting more.
Kevin's dossier of blueprinted boats is quite amazing.
Anyways, you can check the bottom of your boat yourself for flatness. Have a professional fix it if you have problems. This is a primary source of speed robbing. This will be my first year of running with a truel
I believe engine work would be better than a full blueprint job. Kevin actually talked me out of a full blueprint job.
SSComp is offline
Old 03-04-2005 | 10:11 AM
SSComp's Avatar
Sandman, I have a spare blower motor if interested. Would even take you 385 on trade (if good). My bro in law needs a new engine in his sea ray.
SSComp is offline
Old 03-05-2005 | 07:21 AM
dsandman6's Avatar
What kind of motor is it the 385 has 115 hrs on it practically new old owner left the key on for 2 days running up the hrs i know the guy so i now that is what happened that was my main reason for thinking about a whipple only problem is i like to run wot for a while so then you run into a heat issue so im not sure what to do you know the age old decission POWER OR RELIABILITY
