XR vs ZR
Old 02-28-2005 | 03:22 PM
Wild's Avatar
Default XR vs XZ
anyway just wandering what the good and bad is of the XZ drives, lookin at a 38 cig with 500s and XZ drives and dont know anything about them
Wild
Wild is offline
Old 02-28-2005 | 04:58 PM
GPM
Default Re: XR vs ZR
XR vs XZ, xr has the stronger straight cut gears in the upper.
GPM is offline
Old 02-28-2005 | 05:43 PM
Wild's Avatar
so the XZ is the weeker drive??????
should i stay away from them??????????
Wild is offline
Old 02-28-2005 | 07:10 PM
GPM
I don't know that much about the XZ, I believe you can put the XR gears in them, CP Performance sells the gears, last I checked they were $585 per set. I'm sure there are others on here that know way more about drives than me. Friends of mine run the XZ s without any problems.
GPM is offline
Old 02-28-2005 | 07:16 PM
hillbilly24's Avatar
they are both upgrades over the standard bravo and in my opinion the reality of the situation is that the HP500 is pushing the limits of any of the Bravo series drives. this is not to say hat they won't hold up but they will treet you how you treet them. If you got the money to play hard and fix em alot go for it otherwise either take it easy or uprgade them to something like the B-Max drive.
hillbilly24 is offline
Old 02-28-2005 | 07:48 PM
GPM
The B-max upper is stronger but as far as I know they still use the merc lower gears.
GPM is offline
Old 02-28-2005 | 07:53 PM
as far as I know you are rught but most bravo failures are either a shattered upper gearset or a broken or twisted driveshaft. there is also the ever popular mash it in gear at high RPM and wonder why it wont come out as your mash the dock.
Old 02-28-2005 | 08:56 PM
The Menace's Avatar
ZR's are extinct. Merc only made them for a short period of time.
The Menace is offline
Old 03-01-2005 | 09:43 AM
Wild's Avatar
ttt, more help please
Wild is offline
Old 03-01-2005 | 10:23 AM
Dock Holiday's Avatar
Charter Member #34
You mean the "XZ" are extinct, not "XR".
On my 2002 model with 500 EFI's the XZ's came standard.
They are 100 % the same unit as the "ZR" except for spiral cut gears instead of straight cut gears as mentioned above.
I would not consider them bad, they just will not handle as much horsepower to them as the XR which was designed to be mated to the 575 SC.
They quit making the XZ a little over a year ago and made the XR the standard drive for the blue motors.
As mentioned, you can easily convert the XZ into an XR.
Good Luck
Dock Holiday is offline
