Head gaskets--Fel-Pro  or Cometic >
View Poll Results: Which head gskt should I use ??
Fel-Pro 17048
44
27.85%
Cometic
101
63.92%
Other brand ??
13
8.23%
Voters: 158. You may not vote on this poll
Old 03-02-2005 | 07:14 PM
Smitty's Avatar
Default Head gaskets--Fel-Pro or Cometic
Please only answer this poll /question if you have had personal experience with the listed gaskets. I have a Gen 6 502 with a Whipple charger. Running up to 8 lbs boost. I am using ARP studs for aluminum heads.
Smitty is offline
Old 03-02-2005 | 07:57 PM
hpy540's Avatar
Default Re: Head gaskets--Fel-Pro or Cometic
2nd waterhole?? i am in process right now and i would like to know what we are talking about with this.
hpy540 is offline
Old 03-02-2005 | 08:10 PM
I prefer the Cometic, especially on a blower motor. The part #for these gaskets is C5333.
Arch260 is offline
Old 03-02-2005 | 08:54 PM
Fel-pro is now offering the same gasket that Cometic uses,
Strip is using them on his motor project if you want a picture of them.
NOBODY is offline
Old 03-02-2005 | 10:48 PM
Had great luck with cometic and 7lbs of boost,I would not use anything else.
blownboat is offline
Old 03-03-2005 | 05:08 AM
Linster's Avatar
Off the Radar
You need to be carful with head gaskets. On the Gev 4 stuff the holes GPM is talking about is open to allow more flow. Its been a while since I've seen a a Gen 4 block but I seem to remeber they do not have that second lower casting hole on the front of the block. I never thought of what GPM is saying but it makes great sense on a blower motor. What you absolutly do not want to do on a Gen 5, 6 block is open the front water passage. That block has a big casting hole, if not blocked by the gasket, will allow water to short circut the head. Water will enter the front of the block go throught the head and right out the intake not causing any water to go through the back of the head. To open the rear hole, you must have a right & left gasket.
If Comectic makes a gasket that does this, it would be great for blower motors. GPM, can you find a part number or is it custom? I now someone doing a blower with Cometic now.
Linster is offline
Old 03-03-2005 | 07:51 AM
Registered User
Cometic is the way to go, the only Fel-pro gasket I use on blower application is 1012 which a receiver groove has to be made on the head to mount this gasket for extra support.
MIAMIBOYZ is offline
Old 03-03-2005 | 08:36 AM
Linster's Avatar
Off the Radar
GPM,
Thanks, that is perfect, he has a 4.600 bore.
Linster is offline
Old 03-03-2005 | 02:07 PM
Ok guys now that I'm past my panic attack Ijust got off the phone with the Cometic tech department 1-800-752-9820 I did get the right ones. Merlin III blocks with Merlin heads uses #C5331 / H1175 gaskets & no right or left . If this is wrong please tell me! I just put one back in & the other is on the stand. I put the heads back on last night!!!!!!!
Cole-One is offline
Old 03-03-2005 | 03:18 PM
TomFTM's Avatar
I have used the felpro MLS gaskets . There part # is 1075 for big block large bore . 4.570 . Tom
TomFTM is offline
